3Yamaha5Banshee0 Posted August 12, 2011 Report Posted August 12, 2011 I just checked the compression on my Banshee and its right arround 100, i was wondering what the danger point is? anyone know? Quote
Larry's Shee Posted August 13, 2011 Report Posted August 13, 2011 Describe EXACTLY how you performed the test. Quote
3Yamaha5Banshee0 Posted August 13, 2011 Author Report Posted August 13, 2011 i took out a spark plug and i hooked a compression gauge to the sparkplug hole on the head and i kicked it 3 times with the key off. Quote
coryv4 Posted August 13, 2011 Report Posted August 13, 2011 i took out a spark plug and i hooked a compression gauge to the sparkplug hole on the head and i kicked it 3 times with the key off. kick it a good 20-30 times per cylinder only way to do it just to make sure and 100 psi seems pretty low Quote
3Yamaha5Banshee0 Posted August 13, 2011 Author Report Posted August 13, 2011 its a 2000 that has never had new rings so im wondering if i should tear it down and fresh up the top end, and no madder how many times i kick it it will only go to about 100-105 psi Quote
coryv4 Posted August 13, 2011 Report Posted August 13, 2011 its a 2000 that has never had new rings so im wondering if i should tear it down and fresh up the top end, and no madder how many times i kick it it will only go to about 100-105 psi then you prolly just need new rings pull the head off and check piston to cylinder clearence and make sure ur cylinder isnt scored up Quote
3Yamaha5Banshee0 Posted August 13, 2011 Author Report Posted August 13, 2011 yeah this winter thats what im going to do, and clean everything up and repaint everything to make it look like new. and i called arroung stock banshee compression is 115-120 and mine is at 100-105 in 10 years i lost 10psi i dont think thats tooooo bad Quote
dirtydownunder Posted August 13, 2011 Report Posted August 13, 2011 both plugs out. wide open throttle. kick till gauge stops moving. Quote
3Yamaha5Banshee0 Posted August 14, 2011 Author Report Posted August 14, 2011 i did that and all i got was about 105 psi Quote
AKheathen Posted August 14, 2011 Report Posted August 14, 2011 what is the difference between cylinders? generally 90psi is the rebuild point, but a good seated set that gets regular use and no sticky build-up can pump out good right up until the day they snap from being worn down. a quick check is the best way to be safe, and you might want to just plan on a re-ring Quote
Larry's Shee Posted August 14, 2011 Report Posted August 14, 2011 Are you ported? Ex timing affects test also Quote
vifferman Posted August 14, 2011 Report Posted August 14, 2011 Doesn't elevation affect timing too? What is the elevation where you live? Quote
vifferman Posted August 14, 2011 Report Posted August 14, 2011 (edited) I found this 'chart': Sea Level 1000' 2000' 3000' 4000' 5000' 18cc 197 178 171 170 165 145 19cc 183 167 160 158 152 137 20cc 169 156 149 146 140 129 21cc 156 145 138 134 128 121 stock 130 125 118 112 106 100 on this thread: http://bansheehq.com/forums/index.php?showtopic=68439&st=0&p=581714&hl="compression%20chart"&fromsearch=1entry581714 hope it helps. Edited August 14, 2011 by vifferman Quote
3Yamaha5Banshee0 Posted August 15, 2011 Author Report Posted August 15, 2011 im not ported all stock banshee, and i have no clue on my sea level, im in michigan if that helps. and if 90 is the rebuild point im ordering rings today lol Quote
Jereme6655 Posted August 16, 2011 Report Posted August 16, 2011 im not ported all stock banshee, and i have no clue on my sea level, im in michigan if that helps. and if 90 is the rebuild point im ordering rings today lol where at in michigan? 100 is gettin pretty low....but its not totally to the rebuild point. and depending if the rings are what has worn or if the cylinders have worn down into a egg shape from natural wear.......just ordering rings could be just a bandaide fix.... Quote
