BansheeBoy96 Posted June 27, 2011 Report Posted June 27, 2011 Going 1/8th mile asphalt racing when racing is it best to use the clutch or speed shift???? Then do i keep throttle pinned or let off to shift drag racers tell me how u do it???? Quote
BansheeBoy96 Posted June 27, 2011 Author Report Posted June 27, 2011 Clutch or no clutch hold the gas while clutching or not...... Quote
Smokestack Posted June 27, 2011 Report Posted June 27, 2011 If you post this in the drag forum....that would help more Quote
bansheedude55 Posted June 28, 2011 Report Posted June 28, 2011 powershift... pin that throttle, and use the clutch to shift. but dont stay on the clutch long gotta be snappy Quote
BansheeBoy96 Posted June 28, 2011 Author Report Posted June 28, 2011 powershift... pin that throttle, and use the clutch to shift. but dont stay on the clutch long gotta be snappy So Dont let off throttle just hold it...... Quote
edgehanger Posted June 28, 2011 Report Posted June 28, 2011 Zing it up. pop the clutch. shift fast as u can. if u got stock gearing you should go through all 6 gears in the 8th mile. Keep doing it and you'll learn quick Quote
BansheeBoy96 Posted June 29, 2011 Author Report Posted June 29, 2011 Zing it up. pop the clutch. shift fast as u can. if u got stock gearing you should go through all 6 gears in the 8th mile. Keep doing it and you'll learn quick 15/40 Quote
Larry's Shee Posted June 29, 2011 Report Posted June 29, 2011 Get a note book and keep notes. Set-up, track coditions, weather, and anything else important. Quote
