im assuming your talking about the water pump cover gasket or the cllutch cover gasket. prolly be a good idea to have them as they are prone to breaking when you take off. if they dont break you should be fine to re use them. but if they do break you could be down a while waiting on the mail man
Do you need a parachute when you jump from a perfectly good plane? Yes.....to answer your questions you should get the new gasket to assure that it wont leak. if you have the old gasket and its still in one piece you MAY be able to get it to seal.......but no guarentees on whether it will or how long it will last if it does seal.
I guess it comes down to if you want a Banshee that is trouble free or if you prefer a problematic basket case that ruins rides.
Edited by jbooker82
