volcrano Posted April 1, 2011 Report Posted April 1, 2011 hey guys,i put a chariot cool head on my stocker,but have a lil liquid around a few studs on the head.now im using stock nuts with some harbor freight copper washers,new of course,but im wondering if u absolutely have to use the acorns that they would give u with the kit.i think if i had the acorns it wouldnt leak around the threads and if it did it wouldnt go anywhere because it would be sealed.is this right?ive been told i can use the stock nuts,but i only warmed it up and a few are having a lil liquid starting to show.i also didnt use the o rings that go around studs,but if i remember correctly u dont with the chariot head.its not leaking at the copper washers,they seem seales to the head,just around a few threads.any help would be awesome. Quote
guns4children Posted April 1, 2011 Report Posted April 1, 2011 my shits leaking also and i do have the acorn nuts and washers that come with the head. its been to cold here to try and fix it. Quote
Jereme6655 Posted April 1, 2011 Report Posted April 1, 2011 i can't remember which head it is for....but i do know that some members wind up having to use a little bit of sealant before they run the nuts on.... Quote
robert0762 Posted April 1, 2011 Report Posted April 1, 2011 i can't remember which head it is for....but i do know that some members wind up having to use a little bit of sealant before they run the nuts on.... x2, I personally never had a problem but a lil sealant should help Quote
robert.b.west Posted April 1, 2011 Report Posted April 1, 2011 I have a chariot head and lost one of the acorn nuts so when I rebuilt it and reinstalled the head I used the a stock nut. The only one that leaked was that one. I replaced it with an acorn and it stopped leaking. A little sealant on the threads would do the trick also if you dont want to use the acorns. Quote
volcrano Posted April 2, 2011 Author Report Posted April 2, 2011 gotcha,im gonna go to fastenal here and see if they got any acorns.if not,sealant it is.thanks fellas. Quote
jbooker82 Posted April 2, 2011 Report Posted April 2, 2011 you might check to see if they have any stato seals. They are like a rubber coated washers. Quote
