geoffisacnt Posted March 31, 2011 Report Posted March 31, 2011 Any of you guys have a technique for gassing up at a pump. My banshee chugs gas and I find myself cutting my rides short cause I need gas and can't just go to a gas station. Do any of you guys have any tricks for mixing the oil and gas at the pump without a can? Quote
okbeast Posted March 31, 2011 Report Posted March 31, 2011 Just use an old gatorade of coke bottle to store some oil. They're 20 oz's, fill accordingly. Quote
12 0 Clock P I M P Posted March 31, 2011 Report Posted March 31, 2011 yah just get smaller oil containers for roughly like 2 gallons this way you can always judge pretty close of you fil up for like three gallons or whatever, or buy a dune tank 5.8 gallons, no stopping Quote
geoffisacnt Posted March 31, 2011 Author Report Posted March 31, 2011 No I mean like how do I properly mix the oil in the gas at the pump. Put the oil in first then gas or gas in the oil and shake the quad a little....haha that's what im confused about Quote
bansheeman2002 Posted March 31, 2011 Report Posted March 31, 2011 No I mean like how do I properly mix the oil in the gas at the pump. Put the oil in first then gas or gas in the oil and shake the quad a little....haha that's what im confused about thats how i do it at the pump put the oil in then put the gas in and move the nozzle around during fill Quote
geoffisacnt Posted March 31, 2011 Author Report Posted March 31, 2011 Haha I don't have the money for a fancy mix cup. I use a baby bottle lol. Thanks though for the info guys, Quote
okbeast Posted March 31, 2011 Report Posted March 31, 2011 The "fancy mixing up" is maybe $10, if that. If you can't afford that, you can't afford gas to fill up a banshee tank. Quote
geoffisacnt Posted March 31, 2011 Author Report Posted March 31, 2011 It was a joke. I have a mix cup. Baby bottle is convenient Quote
bode1 Posted March 31, 2011 Report Posted March 31, 2011 Last time we had to do that, we just filled up at the pump and added the correct amount of oil straight from the quart using the clear section on the sides with ounce marks. We use Klotz, IDK what oils have those marks, I would assume most. We just eyed it up. I was stressed about getting it wrong, and blowing it up, but after a couple of days like that, it was no big deal. Quote
geoffisacnt Posted March 31, 2011 Author Report Posted March 31, 2011 Yea im not worried about crrying the oil you can fill a baby bottle with enough for 3 gallons. Im worried aabout mixing the oil and gas properly. Quote
Snopczynski Posted March 31, 2011 Report Posted March 31, 2011 Fill your tank to the top, then drain the gas into a graduated container with the fuel petcock set to just "on". Check how many gallons it is in the container that drained out in just the on settiing. Then measure out your oil for that many gallons, and keep it with you. When you hit reserve and go to the gas station, just put in exactly how many gallons you originally found that drained out, and put the oil in as well. You should have pretty close to a full tank of fuel at that point + or - what was left in the reserve section of the tank. Quote
bansheeboi Posted March 31, 2011 Report Posted March 31, 2011 get you a possum box and carry your oil with no problem Quote
252wheelieking Posted April 1, 2011 Report Posted April 1, 2011 It was a joke. I have a mix cup. Baby bottle is convenient I don't have a mix cup & would not buy one over a baby bottle. A baby bottle is all I ever used & works perfect. I treat my shee like a new born baby, you have to feed her buy the ounces....lol....what is a better measurment than a baby bottle to feed by the ounces..... $1 baby bottle vs $10 mix cup. Quote
jbooker82 Posted April 1, 2011 Report Posted April 1, 2011 (edited) I don't have a mix cup & would not buy one over a baby bottle. A baby bottle is all I ever used & works perfect. I treat my shee like a new born baby, you have to feed her buy the ounces....lol....what is a better measurment than a baby bottle to feed by the ounces..... $1 baby bottle vs $10 mix cup. I guess mine is a rageing animal that has been pulled off the Tit a long time ago. http://www.maximausa.com/shopping/index.php?main_page=product_info&cPath=17_19&products_id=27 Edited April 1, 2011 by jbooker82 Quote
Banshee xXx Posted May 22, 2011 Report Posted May 22, 2011 stick a water bottle filled with gas in your air box!!! Quote
