lug nut Posted March 26, 2011 Report Posted March 26, 2011 can any tell me why my 1988 banshee does not take throttle. this motor has not run in three years, I put penetrating oil in the cylinders and let set. then took the carbs off , cleaned them although they looked brand new in side. put them back together. turned motor over easy it was not set up. checked comp it had 105 psi . I then filled the carbs fith fuel and tryed to start. the motor started but acks like it runs on one cylinder then two then one then shuts off. I started it back up and as it is idleing I sprayed the base gasket with carb cleaner to see if there was any leaks, all was good I then sprayed the cleaner on the top os the carb where that cable housing fastens to the carb top the motor picks up rpm and sounds great. what it going on with these , is there some seal I have to change ? hope some one can help thanks jim Quote
BigRed350x Posted March 27, 2011 Report Posted March 27, 2011 can any tell me why my 1988 banshee does not take throttle. this motor has not run in three years, I put penetrating oil in the cylinders and let set. then took the carbs off , cleaned them although they looked brand new in side. put them back together. turned motor over easy it was not set up. checked comp it had 105 psi . I then filled the carbs fith fuel and tryed to start. the motor started but acks like it runs on one cylinder then two then one then shuts off. I started it back up and as it is idleing I sprayed the base gasket with carb cleaner to see if there was any leaks, all was good I then sprayed the cleaner on the top os the carb where that cable housing fastens to the carb top the motor picks up rpm and sounds great. what it going on with these , is there some seal I have to change ? hope some one can help thanks jim Sounds like maybe TORS system. Why did you put penetrating oil in the cylinders? Whats your jetting? Checked reeds for cracks? Got good plugs? Right wires on the right contacts on the coil? Spark plug caps good? Pickup coil gap set right? There a LOT to check out if it hasn't been run in a long time. If I were given an engine that I knew had been sitting for that amount of time, I would probably do a complete tear-down and replace all the seals and gaskets. Quote
lug nut Posted March 27, 2011 Author Report Posted March 27, 2011 Sounds like maybe TORS system. Why did you put penetrating oil in the cylinders? Whats your jetting? Checked reeds for cracks? Got good plugs? Right wires on the right contacts on the coil? Spark plug caps good? Pickup coil gap set right? There a LOT to check out if it hasn't been run in a long time. If I were given an engine that I knew had been sitting for that amount of time, I would probably do a complete tear-down and replace all the seals and gaskets. It has good comp and starts on first kick, But I have found it needs a gasket or some kind of seal between the carb cap and the tors, when I spray garb cleaner around that area the motor sucks on that cleaner sealing off the leak for a second and the wheeler run fine for 30 seconds, it acks just like a intake leak leaning it out. thought maybe there were problems with these ? Quote
Jereme6655 Posted March 27, 2011 Report Posted March 27, 2011 shit.....look slike its time to either just ditch the TORS or you can also temporarily throw some chaulk or some sealant to goop up those holes... Quote
lug nut Posted March 27, 2011 Author Report Posted March 27, 2011 shit.....look slike its time to either just ditch the TORS or you can also temporarily throw some chaulk or some sealant to goop up those holes... well just came back in from working on banshee, the reason it was sucking in the card cleaner is I never put the cross over tube back between the carbs, now it seems to be the tors the machine will start and idle but the min i as much as touch the throttle the motor stops. Is there any fix to these or file them and put reg carbs on? if i can put reg carbs on is there anything I have to do to the wireing to get the ing to fire? I did think that maybe the left crank seal was tore so I pulled the side cover started the motor and sprayed card cleaner around seal and the motor ran the same , I us the spray to find leaks it works great as long as you dont start a fire ,wd -40 works good to . anyone have any ideas? Quote
tedd1 Posted March 28, 2011 Report Posted March 28, 2011 Under and in front of the gas tank, on the left side, a small black box, unplug it, if TORS is the problem, this should fix it. Quote
lug nut Posted March 28, 2011 Author Report Posted March 28, 2011 Under and in front of the gas tank, on the left side, a small black box, unplug it, if TORS is the problem, this should fix it. I unplugged it ,that worked , Thanks Quote
