well just came back in from working on banshee, the reason it was sucking in the card cleaner is I never put the cross over tube back between the carbs, now it seems to be the tors the machine will start and idle but the min i as much as touch the throttle the motor stops. Is there any fix to these or file them and put reg carbs on? if i can put reg carbs on is there anything I have to do to the wireing to get the ing to fire? I did think that maybe the left crank seal was tore so I pulled the side cover started the motor and sprayed card cleaner around seal and the motor ran the same , I us the spray to find leaks it works great as long as you dont start a fire ,wd -40 works good to . anyone have any ideas?
