burhead Posted February 1, 2011 Report Posted February 1, 2011 Finally got my R2s coated with DIY cherama chrome. The stuff was pretty easy to apply and looks great. I hope it holds up well and does what it claims to do. Quote
RZBansheeMan Posted February 1, 2011 Report Posted February 1, 2011 Nice looking.. Hope they hold up well for ya too. Quote
burhead Posted February 4, 2011 Author Report Posted February 4, 2011 Well this coating is as durable or better than powder coating. How do I know? I had to strip one of the pipes down. When I baked it, it bubbled up. I thought "no bid deal, nothing a little sandblasing cant handle". Wrong. After 2 hours and only about half of the pipe done, I went to air craft stripper followed up with 60 grit sand paper. Still have to hit all the welds with the sand blaster and recoat. The "grill paint" that came on these pipes was completely stripped from the pipe in about 20 minutes. Quote
06specialedition Posted February 4, 2011 Report Posted February 4, 2011 Looks good..hope it holds up. Keep us updated Quote
camatv Posted February 4, 2011 Report Posted February 4, 2011 always pre heat all parts to be coated. Quote
sstaton1983 Posted February 4, 2011 Report Posted February 4, 2011 never herd of it. is it a kit? or like spray paint? any info would appreciated. Quote
burhead Posted February 5, 2011 Author Report Posted February 5, 2011 They were still wet in the picture. After I baked them they dulled down a bit. They look more like raw aluminum now. The product is available from tech line coatings. It is spray on. I bead blasted the pipes then applied the coating using a 15 dollar harbor freight detail gun. They look much better than black IMHO especially since my bike has a silver frame. There are several colors available, this one is "aluminum". I was going to go with the titanium finish and will probably try that on the next pipe I do. Quote
burhead Posted February 10, 2011 Author Report Posted February 10, 2011 (edited) Finally got them installed on the bike. I can't wait until the weather warms up so I can try them out. The look is pretty much what I was going for. They look like an unpolished aluminum piece. Edited February 10, 2011 by burhead Quote
sprinklerman Posted February 10, 2011 Report Posted February 10, 2011 Its durable. I used to use it a lot about 13-14 yrs ago. If you bake it right you can barely get it off when you want to. It polishes up close to polished aluminum if you use a vibratory polisher on the piece . I've even used it on piston tops. Quote
burhead Posted February 16, 2011 Author Report Posted February 16, 2011 Finally got to get some seat time over the last couple of days. Just went out and played on some gravel roads because we still have alot of snow covering everything else. I am very happy with these pipes and the coating as well. After a long ride down the road, I can touch the pipe and not get burned. These pipes perform just as the other reviewers said. They hit hard in the mid range and just keep pulling. I am coming from fattys and while I think they are a great pipe, especially for trails, they fall off too soon for my liking. The fattys did have a little more in the low mid range and I found the power on the R2's seem to kick in a little later. I'm happy for now but I will have to see how they do in the trails. I am also running the same jetting as my fattys and will have to play around a bit and see what works best. Quote
06specialedition Posted February 16, 2011 Report Posted February 16, 2011 Finally got to get some seat time over the last couple of days. Just went out and played on some gravel roads because we still have alot of snow covering everything else. I am very happy with these pipes and the coating as well. After a long ride down the road, I can touch the pipe and not get burned. These pipes perform just as the other reviewers said. They hit hard in the mid range and just keep pulling. I am coming from fattys and while I think they are a great pipe, especially for trails, they fall off too soon for my liking. The fattys did have a little more in the low mid range and I found the power on the R2's seem to kick in a little later. I'm happy for now but I will have to see how they do in the trails. I am also running the same jetting as my fattys and will have to play around a bit and see what works best. Good to hear, I've been hearing good things about the R2's. Wow so that stuff must really keep them cool huh? Those pipes sure sit pretty high up, that would take some getting used too. Quote
MikeNick Posted February 16, 2011 Report Posted February 16, 2011 Nice job man..They look good. Quote
