tedd1 Posted February 9, 2011 Report Posted February 9, 2011 CALL A SITE SPONSOR!!! You can get it done for half of that, maybe less, even with shipping. I don't know how we could be any clearer. Quote
GYTWYPT Posted February 9, 2011 Report Posted February 9, 2011 $900 Wow you could almost get a set of Serval cubs for that with Pistons. If you are planning on spending that much you might as well ship your whole motor out and let one of these guys get it all taken care of for ya. Seems real expensive to me, but then again I try and do all the work I can myself. I think I could do a whole topend for about $300 with machine work. Good luck on your choice Quote
robert0762 Posted February 10, 2011 Report Posted February 10, 2011 Looks like you had some deto on the cltch side. i would tear it down and put new crank seals in while your down . It always seems like the right side seal goes first. Quote
Jereme6655 Posted February 10, 2011 Report Posted February 10, 2011 yea.....about what that guy said.......what the hell is he doing about carbs? if im reading that correct then i think that your saying he want to replace them? why...theyre fine...haha. just cause it may have snagged a ring doesn't mean you need to change carbs lol. like was mentined earlier....you could send out your motor to a sponsor and get it fully rebuilt and heavily modded for that price..... Quote
Larry's Shee Posted February 10, 2011 Report Posted February 10, 2011 Yeah, I've heard of your mechanic. He's worked all over the place. His name is Ben Dover. If you paid $1000 for it and you put $900 into it , you're not going to get $1900 out of it. If you know which end of a wrench to grab you can do it your self. If you wanted to be cheap and peddle it you could throw a set of rings in it and dump it. Cheap pistons and rings ,hone job , dump. Do it right yourself and keep it and have something to build on. You can get stock carbs all day long for less than $100 , tho your engine would die long before enough dirt went through carbs to totally destroy them. JMHO, your results may and will vary. Quote
