i have the same thing, 19cc domes in a pro design head. i have 180psi in each cylinder. i run at sea level and i have been running VP c12 rase gas. its around 108 octane.
Edited by shoopie
without compresion test you never know 160 comp and below run 92 but 165 and above start mixing 110 and 92 atleast
actually...if you really want to know, you need to figure out what kind of dynamic compression, and other variables........93 can start to detonate anywhere between 140psi and 190psi, really.....
