i pulled my silencers apart yesterday to drill and install some sheet-metal screws because the rivets on my P.C. 2's were wearing off. i pulled the cap off of one and it was completely empty. no packing, no insert tube, nothing. the thing is, my bike ran great when it was running a few weeks ago. is it okay for the motor to run it with no packing? i am definitely going to buy some packing and make some tubes for them but is it okay for me to run it for now until i do that? also when i put the packing in will i have to change my jetting? thanks guys.
-Ryan
Edited by shoopie
also, do the insert tubes go from the headpipes all the way through to the tips of the silencers or do they only go part of the way through?
The tubes should go all the way to the tips, thats how there held solid. I would disagree that the packing is only to quiet it down.
not really trying to be a smart ass or anything but what else would it be for? :confused:
-Ryan
Yeah it will be fine to run for now just kinda f'ing loud lol. No you won't have to rejet.
Worn out or missing packing will cause a loss of power through turbulence in the silencer. If you dont believe me take your packing out.
Yep packing keeps the exhaust flowing straight through the perforated center core. With no packing there is a lot of turbulence in the exhaust silencer. That causes a decrease in exhaust flow which causes a drop in hp. But hay it sounds bad ass. :rotflmao:
that's the first thing banshee owners do to give it that fart can effect for your fat ass and run 100 to 1 in the gas then let the bitch run it on strait gas ha ha
Need to have a good clean perforated core in there. It will pick up trq/hp with good packing in it. Make sure to wrap the new packing TIGHT and use strips of Masking tape about every 2-3 inches. Use new rivets or locktight the bolts in the endcap.
:huh: thats really confusing
Yes it does sound bad ass lol :cheers:
