pondtunes Posted June 19, 2010 Report Posted June 19, 2010 this isn't good I know! waterpump? It wasn't blowing white smoke that im aware of i have until july 2nd to fix this! Quote
jbooker82 Posted June 19, 2010 Report Posted June 19, 2010 this isn't good I know! waterpump? It wasn't blowing white smoke that im aware of i have until july 2nd to fix this! How is the coolant level? It wont blow white smoke because the oil doesn't lubercate any engine parts. Quote
pondtunes Posted June 19, 2010 Author Report Posted June 19, 2010 How is the coolant level? It wont blow white smoke because the oil doesn't lubercate any engine parts. Coolant was empty, I noticed the white stuff coming out the crank overflow dripping everywhere, hasnt been happening long I dont think because i haven't seen it on the shop floor. put water in and it was hot but i dont *think* i overheated it very short ride. Quote
SAVAGE420 Posted June 19, 2010 Report Posted June 19, 2010 Change the pump seal, it's leaking. Do the bearing also since your in there. 1hour job messing around. Quote
THE358BANSH Posted June 19, 2010 Report Posted June 19, 2010 Change the pump seal, it's leaking. Do the bearing also since your in there. 1hour job messing around. X2, got my seals off ebay from a vintage cycle shop in Nebraska. Buy 2 seals and a bearing just to be safe if there is a next time...Evan Quote
jbooker82 Posted June 19, 2010 Report Posted June 19, 2010 Yea tear it down to do a pump seal and bearing. Now would be a good time to upgrade to a billit impeller. Quote
FrankieSquid Posted June 19, 2010 Report Posted June 19, 2010 Time to upgrade. Hit up Alfie or Brandon at MULL engineering to name a few. Site sponsors have great prices on shit like that. Quote
spurdy Posted June 19, 2010 Report Posted June 19, 2010 What water pump you running? Sometimes cheap after market billet water pumps have shitty shafts. The seal wears a groove in the shaft and that is what leaks. Good seal and all but the shaft is the problem. Just make sure while you have it apart that the shaft isn't grooved. No good seal will fix that. SP Quote
zachmw Posted June 19, 2010 Report Posted June 19, 2010 If its not the pump seal, take the clutch cover off there is a pipe that runs through the case that has a O-ring on it, if that goes bad it will leak coolant into the tranny. Quote
