well i currently gave my shee a make over and when i got to the air filters i removed the k&n pods and installed a toomey single, and when i started jetting i realized that it was restricting the air flow. so i'm lookin for input, what do you run or what sugestions. all input is appreciated
heres my set up:
.040 over wisecos
stock stroke
coolhead 20cc domes (for now) 155 psi
port work
stock carbs no tors
dyno jet kit
4th clip 340mains sea level to 1000ft
no air box
stock cages
dual stage reeds
timing plate 4 degrees
fmfs
91 octane
this will depend on where you ride. do you ride where its wet or with a lot of water holes? if not, id run clamp on k&n's. if so, id run some sort of intake that utilizes the stock air box.
i dont ride through water but i do ride in sand, i had k&ns but they where heavy and they floped and they would fall off
I run the sand and LOVE the pod filters(K&N clamp on)when the air box is removed i use the mounting tabs and put zip ties through the holes and around the filters to help support them.
thats what i didnt like about k&n heavy, flop and they fall off. i guess a support system would be helpful thanks
