i have a 02 banshee boysen reeds k&n and 12 holes in lid. if i mount silencers onto the stock pipes would i benefit any power???? this is only until i canbuy pipes..... if so what size mains and pilots should i use
Edited by bansheemann420
Don't think you will gain anything from that.
dont bother,,,just pick up a used set of pipes when u can afford it,,,u will be very happy when you do,,,just dnt forget to rejet!
oh ya,,,if you have 12 holes drilled in the lid you may as well just ditch the pos when you get pipes,,,but if you ditch it now you may have to go up on your mains,,,,so i would just wait to you get pipes,,then ditch the lid and rejet accordingly
X2 on that
