bansheemann420
Everything posted by bansheemann420
  1. wishing i had 18000 dollars to pay fuckin electric bill. fuckin obama
  2. would 20x10x9 look funny or fit on stock rims
  3. i need some 20x11x9 tires for cheap 70 bucks dont need brand new tires just something with some tread left
  4. 02 banshee needs a oil change clutchis slippin a little i heard of atf type f but idk what is it or where to get it from and price can someone help???
  5. i got mine off here itsa dynoport i think it sounds good........ jus check the for sale forum and look around people are going to tell you your better off getting something else for the price......
  6. ive removed tors wires and box and sensor from throttle its not that once, i get into like 4th and 5th and give it half throttle itpulls fine,but 1st-3rd it bogs at low to mid sputters a lil then clears up around powerband. also bogs when trying to rev sitting still
  7. none.... i went to a 260 from a 240 and its been running after rebuild i just bought a adjustable timing plate when i put that on will the jettin have to be done also???????? should my jetting be higher b/c of the bore?
  8. 02 banshee bored .060 over less than 2 hours on it ,dyno port exhaust, boysen power reeds, k&n, no lid pilot25 main 260 clip in middle position, it idles butwhen i go to rev, it smokes and it will rev but only half way then it sputters??????/? anyone???? help please.... thanks
  9. is abanshee head gasket bore specific i have a full tusk topend set laying around wondering if it would fit. bikes bored 60 over and some bright person decided to put the head gasket on upside down so it leaks smoke and gas under the head just wondering if it would fit thanks in advance guys
  10. so does anyone know how much is between the cylinders and the piston i dont wanna have to do this again right away
  11. yeah some say diffent
  12. so when i took apart a buddys banshee the other day the cylinders were screwed a huge gouge in it i took it to a machinest they said it would have to be bored 60 over to a 65.5mm . we got some namura piston full kit with gaskets and bearings all brand new and cheap i neeed to know what gapping some said .002-.004 just want to be sure of what will be needed to be done so i can tell the machinest... thanks guys in advance
  13. not too sure on this one its a buddy of mines idk really anything about who did the work before. basically a problem that was rigged and handed down
  14. not too sure what happened went riding started smoking badddd and it still started up idled and ran until i took it apart of course when i took it apart the rings just fell off into like 6 pieces anyone with some knowledge thanks
  15. are stock bars aluminum or are they steel
  16. go to rockymountainatvmc.com there like 2.50 a piece and youll need to go up on your pilots 27.5 there about the same price
  17. if my jetting is correct
  18. k&n With airbox and lid
  19. 02 banshee 2to1 pipe and silencer k&n airbox and boysen power reeds.... elevation is sealevel.... i have a 25 pilot in and a 260 main thanks guys
  20. title says it tryin to find one real cheap if possible anyone?
  21. do you have a adjustable timing plate??????
  22. where could i get some?????
  23. thanks guys its pretty caked on bad could i use a wire brush???
  24. my pistons are a lil black on top what can i use to clean them up a lil bit??? firgured it would help
