bansheemann420 Posted June 3, 2010 Report Posted June 3, 2010 (edited) i have a 02 banshee boysen reeds k&n and 12 holes in lid. if i mount silencers onto the stock pipes would i benefit any power???? this is only until i canbuy pipes..... if so what size mains and pilots should i use Edited June 3, 2010 by bansheemann420 Quote
pr0blumz Posted June 3, 2010 Report Posted June 3, 2010 i have a 02 banshee boysen reeds k&n and 12 holes in lid. if i mount silencers onto the stock pipes would i benefit any power???? this is only until i canbuy pipes..... if so what size mains and pilots should i use Don't think you will gain anything from that. Quote
06specialedition Posted June 3, 2010 Report Posted June 3, 2010 Yeah It mite make it a little louder, but I don't think you would notice much of a gain if any. I'm sure there is people or here who would make you a good deal on some used pipes Quote
shawn941 Posted June 3, 2010 Report Posted June 3, 2010 i have a 02 banshee boysen reeds k&n and 12 holes in lid. if i mount silencers onto the stock pipes would i benefit any power???? this is only until i canbuy pipes..... if so what size mains and pilots should i use dont bother,,,just pick up a used set of pipes when u can afford it,,,u will be very happy when you do,,,just dnt forget to rejet! Quote
shawn941 Posted June 3, 2010 Report Posted June 3, 2010 i have a 02 banshee boysen reeds k&n and 12 holes in lid. if i mount silencers onto the stock pipes would i benefit any power???? this is only until i canbuy pipes..... if so what size mains and pilots should i use oh ya,,,if you have 12 holes drilled in the lid you may as well just ditch the pos when you get pipes,,,but if you ditch it now you may have to go up on your mains,,,,so i would just wait to you get pipes,,then ditch the lid and rejet accordingly Quote
alf44 Posted June 3, 2010 Report Posted June 3, 2010 oh ya,,,if you have 12 holes drilled in the lid you may as well just ditch the pos when you get pipes,,,but if you ditch it now you may have to go up on your mains,,,,so i would just wait to you get pipes,,then ditch the lid and rejet accordingly X2 on that Quote
yfz350rider Posted June 3, 2010 Report Posted June 3, 2010 x3... removing the lid without rejetting will make it run horribly. Quote
