shakenbake1285 Posted May 18, 2010 Report Posted May 18, 2010 I just synced my carbs n now the bike walnt idle n when I ride it it has a hesitation on the bottom end. I have the tors removed Quote
bansheemann420 Posted June 2, 2010 Report Posted June 2, 2010 I just synced my carbs n now the bike walnt idle n when I ride it it has a hesitation on the bottom end. I have the tors removed ive got the same problem only theres no answers!!! Quote
T_Shee Posted June 2, 2010 Report Posted June 2, 2010 the choke tube didnt come unhooked did it? did you turn the idle down when you synced them? if you didnt lower the idle on either carb while syncing them then you must have another issue. if you did turn one down then just turn them both back up equal amounts. Quote
pr0blumz Posted June 2, 2010 Report Posted June 2, 2010 the choke tube didnt come unhooked did it? did you turn the idle down when you synced them? if you didnt lower the idle on either carb while syncing them then you must have another issue. if you did turn one down then just turn them both back up equal amounts. x2, choke tube not connected. Quote
ClimbAnyHill Posted June 2, 2010 Report Posted June 2, 2010 Make just need to turn the idles screws in and raise those slides. Are the back of slides letting air/fuel in? Take carbs off and look in in the back to make sure. Quote
