overrevtricky Posted May 16, 2010 Report Share Posted May 16, 2010 I love learning about motors, especially the banshee, but this one got me stumped! I've been reading on here lately about 4mil stroker cranks with 110mm rods and 115mm rods. What in the world is the difference?! Quote Link to comment Share on other sites More sharing options...
98_shee Posted May 16, 2010 Report Share Posted May 16, 2010 110 has stock length rods and 115 is 5mm longer than stock. With the 115 you need to run 795 series pistons they are offset to compensate for the longer rods. Quote Link to comment Share on other sites More sharing options...
overrevtricky Posted May 16, 2010 Author Report Share Posted May 16, 2010 Thanks man. Now I know what the deal on blaster pistons is too. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted May 16, 2010 Report Share Posted May 16, 2010 Thanks man. Now I know what the deal on blaster pistons is too. If you have a long rod stock stroke then you can run blaster pistons. You will need different domes though. Blaster pistons have a flatter crown and are a little shorter. If your running a long rod 4 mill then you can run blaster pistons. You will need custom domes. They need to be cut for the stroker and be cut at a different angle. Quote Link to comment Share on other sites More sharing options...
overrevtricky Posted May 17, 2010 Author Report Share Posted May 17, 2010 Alright, so the shorter blaster piston compensates for the longer rod in stock jugs, correct? Quote Link to comment Share on other sites More sharing options...
Infamous039 Posted June 6, 2010 Report Share Posted June 6, 2010 So what is needed to run a 4mil 110rod crank. Will you notice power increase with the 4mill 110rod and do you need custom domes/pistons etc. ????? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted June 6, 2010 Report Share Posted June 6, 2010 So what is needed to run a 4mil 110rod crank. Will you notice power increase with the 4mill 110rod and do you need custom domes/pistons etc. ????? cut stroker domes, or a spacer plate. The 110 rod stroker crank uses stock banshee pistons. I wouldnt run one though because they are harder on piston skirts. josh Quote Link to comment Share on other sites More sharing options...
firebanshee Posted June 7, 2010 Report Share Posted June 7, 2010 Alright, so the shorter blaster piston compensates for the longer rod in stock jugs, correct? The wrist pin height is raised to compensate for the longer rod. Quote Link to comment Share on other sites More sharing options...
Infamous039 Posted June 11, 2010 Report Share Posted June 11, 2010 So if you u run stroker domes then you dont need the spacer plate??? If you run the psacer plate, you can run standard domes????? cut stroker domes, or a spacer plate. The 110 rod stroker crank uses stock banshee pistons. I wouldnt run one though because they are harder on piston skirts. josh Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted June 11, 2010 Report Share Posted June 11, 2010 So if you u run stroker domes then you dont need the spacer plate??? If you run the psacer plate, you can run standard domes????? Yep but it is pretty point less to run a cool head with standard domes and a spacer plate. Most of the time people use a spacer plate and a stock head. Cool head domes are just to easy to make compaired to machining a stock head. The one thing you have to remember about the spacer plate is that since it raises the jugs up 2mm it also advancess all the port timings by 2mm's. Quote Link to comment Share on other sites More sharing options...
camatv Posted June 11, 2010 Report Share Posted June 11, 2010 any stroker crank should be installed by someone who knows the tricks to get them to run droping in one with a spacer plate and messed up domes can result in a motor thats SLOWER than a properly built 350cc.. blaster pistons are'nt availabe till 66mm bore i believe. the 795 series is banshee style pistons in the lower bore's. also basegasket thickness and dome squish clearance all plays a part in a bomb motor or one thats reliable and runs like it should. Quote Link to comment Share on other sites More sharing options...
