96 banshee racer Posted April 20, 2010 Report Posted April 20, 2010 (edited) hey, i have a 1996 yamaha banshee, and when i go full throttle, it just flutters and the powerband wont kick in, need some help please, because what is a banshee with out its powerband? i dont know if this will help at all but, it has the following modification... ported and polished jugs advanced triming kit 2 into 1 trinity intake american racing 2+2 A arms dura blue axel maxxis tires front +rear 1 1/4" handle bars pro circuit pipes high volume water pump inline cooler barrett heavy duty clutch Vito's pistons milled head AC nerf bars AC skid plate (front and rear) PRM grab bar Elka Front Shocks Edited April 20, 2010 by 96 banshee racer Quote
SAVAGE420 Posted April 20, 2010 Report Posted April 20, 2010 Just happen outa the blue one fine day? What carb are you running? Also your main, pilot, needle, air screw set at and whats your clip position. (If you don't know, pull your bowl and carb cap off and have a look). Whats your Elevation and outside temps? You running i pod filter i suspect? You have a for sure strong spark? Quote
96 banshee racer Posted April 20, 2010 Author Report Posted April 20, 2010 (edited) Just happen outa the blue one fine day? What carb are you running? Also your main, pilot, needle, air screw set at and whats your clip position. (If you don't know, pull your bowl and carb cap off and have a look). Whats your Elevation and outside temps? You running i pod filter i suspect? You have a for sure strong spark? it was sorta out of the blue, once i oiled my air filter, k&n one with oil, it stopped working, so then i cleaned the oil off it and it dident kick in, and then i tryed running a drag twst with no filter and it dident kick in.--- also cleaned sparks like 3 times with the fluid stuff and i wiped with paper towel, i did not sand them Edited April 20, 2010 by 96 banshee racer Quote
SAVAGE420 Posted April 20, 2010 Report Posted April 20, 2010 it was sorta out of the blue, once i oiled my air filter, k&n one with oil, it stopped working, so then i cleaned the oil off it and it dident kick in, and then i tryed running a drag twst with no filter and it dident kick in.--- also cleaned sparks like 3 times with the fluid stuff and i wiped with paper towel, i did not sand them Do you think you over oiled it the first time around? Did you oil it again and try or was it just dry. I say check what your main jet is and try a new plug just for shits and grins. Quote
lt500rbigbore Posted April 20, 2010 Report Posted April 20, 2010 probably carb... might have water in your gas to... just my 2cents Quote
firebanshee Posted April 20, 2010 Report Posted April 20, 2010 I think it is the 1 1/4 inch handle bars Could also check plug caps. Quote
LS1Inferno Posted April 20, 2010 Report Posted April 20, 2010 Whenever somthing like this happens, the first thing i do is clean the carbs. In your case the carb, try new plugs also, dont just clean them sometimes that doesn't work. Quote
White97Banshee Posted April 22, 2010 Report Posted April 22, 2010 Swap the blue powerband out for the yellow one Just kidding. Clean the carbs and check for anything clogging air/fuel passages! That happened to me when my spark arrester was clogged up it wouldn't get on the pipes and it pissed me off. Quote
