what would be the best cool head and domes for my banshee with dmc916,booyseen reeds,Kn filter.
NOSS makes a good head and domes and is a site sponser, just click on his banner at the top of the page when you see it. He can help with dome choice, there are alot of things to consider when choosing domes, what fuel do you want to run, what elevation you are at, how much compression you want your motor to have.
Yea, give me a call or most (but not all) of the BHQ sponsors carry the Noss heads and domes.
-David
are coolheads just a gimmick or do they actually work?
as far as bumping up compression hell yes they work,,,as for cooling the engine better i have heard varying things......
I just put a noss cool head on my stock 03banshee with 21cc domes..... It kicks out 148psi compression on each bank......
Just run 91or 93octane fuel, and you should be fine..... Oh, and im at 945 feet elevation..... It seems when you go 20cc domes or lower,
then you need to be more worried about mixing some higher octane fuel with the pump gas.....
