03badazzbanshee
Everything posted by 03badazzbanshee
  1. south jersey in lindenwold the cops come back there every once in a while but I have not been bothered yet.
  2. could try kemco lead supreme only 1 that i heard works.
  3. Im pretty sure there are no airleaks checked choke tube took it off n put it back on again emptyed out gas and put in fresh gas and nothing also i have to hold the gas to start it and takes me about 20 kicks to start and sometimes backfires when kicking oil spits out of pipes to.
  4. ok so I have dropped to a 270 main and moved needle clip. Now the bikes still smoking like crazy, dosent rev up clean,sometimes smoke changes from one cylinder to the other and it sounds like a old blaster also spark plugs are oily but the oil can be wiped right off and plug looks clean again??
  5. ok thanks so ill drop to a 270 main and throw in fresh plugs.
  6. dmc 916s,k&n filter, booyseen reeds, 100ft above elevation 280 mains and about 60s and 70s temp.
  7. My banshee bogs and does not rev all the way up until like 3rd gear. Smokes up everything, spark plugs wet ond oily. any ideas?
  8. If you just cut a whole in it no but if you take it off it will effect jetting acording to dmc. I dont think it will make much of a difference but i just kept my lid on.
  9. K&N pods no lid or box on filter reeds, aftermarket water pump and if you want a cool head.
  10. 21cc domes would be fine with pump gas and above sea level?
  11. what would be the best cool head and domes for my banshee with dmc916,booyseen reeds,Kn filter.
  12. Comes with 270 and 280 mains with needle.
  13. i run it and i dont see any build up.
  14. dmc 916s all the way loud and they sound diff than anyother pipes.
  15. anyone use klotz nirto power additive ? I was gonna get some.
  16. If you think ur banshee will be siting for awhile try using some fuel stabilizer but i agree with the other guy.
  17. OK t5 work better with mods and t6s work better with less modifieded banshee t6s creates more low-end and mid-range power the T6 is 8 hp over T5 on top end, and 5 hp over T5 on acceleration, thye put out around 55hp in the midrange. Both very good sounding pipes but t6s might be a lil louder but if u plan to do work to motor stick wit t5s .Hope this helps.
  18. Do you think 270 jets should be good with reeds DMC916s K&N filter or 280 jets since its almost winter ?? thanks
  19. All banshee owners must buy a aftermarket water pump because stock plastic 1 is garbage. Just given u the heads up so ur waterpump wont start melten !
  20. still have the 916s ?
  21. i just orderd them today!!
  22. Do boost bottles help in performance and which is the best boost bottle ?? thanks
  23. lol thanks and i will be ordering them this week hopefaly
