demon Posted March 28, 2010 Report Posted March 28, 2010 I got my freinds banshee here .It was stollen 4 years ago ,he got it back ,had it for 2 weeks ,got stollen out of his truck again,and he got it back again. so It's in my garage now locked up. it would start up if you push started it so I checked the comp .I was bad so we got the cylinders bored and new pistons .the old ones were baaadd! now I tried to start it with the kick starter and nothing so we pulled it with my 4 wheeler and it fired right up. drove it aroud for a bit .the directions said 1/2 throttle for 5 hours. I ran it for maby 10 minutes . this morning tried to kick it again . wont start, so I pulled it again and it ran . ran it for maby 5 min. it kick starts after it gets hot. I let it cool for 4 or 5 hours and tried to kick it again. It fires on the first kick but almost starts to run .then I keep kicking and nothing.let it sit for sa wile and does exactlly the same thing .I can keep doing this with the same result. whats up with that Quote
bonerific250 Posted March 29, 2010 Report Posted March 29, 2010 sound like you might have the float bowls switched.the bowl with the jet and brass tube in it goes on the left side. Quote
firebanshee Posted March 29, 2010 Report Posted March 29, 2010 sound like you might have the float bowls switched.the bowl with the jet and brass tube in it goes on the left side. Nice TITS Quote
jgalvan Posted March 30, 2010 Report Posted March 30, 2010 I got my freinds banshee here .It was stollen 4 years ago ,he got it back ,had it for 2 weeks ,got stollen out of his truck again,and he got it back again. so It's in my garage now locked up. it would start up if you push started it so I checked the comp .I was bad so we got the cylinders bored and new pistons .the old ones were baaadd! now I tried to start it with the kick starter and nothing so we pulled it with my 4 wheeler and it fired right up. drove it aroud for a bit .the directions said 1/2 throttle for 5 hours. I ran it for maby 10 minutes . this morning tried to kick it again . wont start, so I pulled it again and it ran . ran it for maby 5 min. it kick starts after it gets hot. I let it cool for 4 or 5 hours and tried to kick it again. It fires on the first kick but almost starts to run .then I keep kicking and nothing.let it sit for sa wile and does exactlly the same thing .I can keep doing this with the same result. whats up with that I had the same problem and I took out the choke pick up jet ( little jet in the bottom of the bowl where the choke pick up tube goes, on the left carb) and cleaned it. I havnt had the problem since, and shee fires right up!! and yes, make sure your bowls are on the correct carb. Quote
firebanshee Posted March 31, 2010 Report Posted March 31, 2010 No really those are some NICE tits. Quote
