I dont understand what difference it makes in who cut the trans.
Anyways, after splitting my cases for some maintenance put my forks in the wrong spot. It would not go into naturalize because it was b/w gears or something. I usually spin the shaft to make sure it's free as soon as the cases are together. I was not happy haha.
You can always take the engine out, turn it upside down and split the cases. That way you leave the juggs on. Just be CAREFUL when putting it back. It's easy to not put the forks in the right place.
Really?
Interesting...
yep. shannon(spurdy) whose WCR 1-5 N down extreme duneable fucked up at my house a few weeks back talked to WCR and thats what they told him. apparently, last year they were using a spring on the rear tranny shaft where they are now using a spacer. thats what they think is causing the problem.
i am not convinced thats what caused his tranny to go bad. i was noticing yesterday on a stock tranny that there is a clip inside the tranny case right behind the idler gear but before the gear. his tranny didnt have that clip and the gear was rubbing the inside of the case. i believe thats what caused the tooth to break off the gear.
Gotcha.
By no means am I trying to stir a pot...this is honestly the first bad thing I've heard about them, and as you said..entirely possible it's not the tranny.
Andy @ M&M has had great success with them AFAIK.
Gotcha.
yea, i know that FAST has already sent a couple back. i think spurdy's is the 3rd to break that came from FAST alone..
