crazyj789 Posted February 19, 2010 Report Share Posted February 19, 2010 Ok here goes Im planning to build a 4 mil shee engine. Here is the list FAST woods port with matched case porting Stock head Paul Turner rechambered Adjustable Timing plate +4 FAST wiseco Hotrods +4mil crank with extra welds bore 1 size over stock with pro-x pistons v-force 3 reeds with open stuffers FAST billet intake with crossover built in Billet bowls for carbs (whatever size I need) FAST straight cut gears and billet basket and clutch kit PT mids with fatboy silencers Stock airbox with foam filter and custom lid and all the other small mods we all know and love bearing wise I mosly ride at the Badlands, Haspin acres, and sometimes Silver lakes. I really enjoy trail with the alot of hills. I need to know what size carbs (Kehin wize) that I should run in Northwest Indiana. What is best!! for this setup also any jetting tips for this setup Thanks alot guys. Lemme know Jason Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 19, 2010 Report Share Posted February 19, 2010 i would ask jeff, but i can almost guarantee he will recommend 33 or 35mm pwk. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted February 19, 2010 Report Share Posted February 19, 2010 Save yourself some money. You don't need straight cut gears and you don't need billet bowls for gas. If you are just building extra for a future build fine, but you don't need those items. For a more trail built bike I would be looking at the 30-33MM range for carbs. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 19, 2010 Report Share Posted February 19, 2010 while i agree you dont really need straight cut gears, i think the billet bowls are a good idea. its not going to hurt you to have that extra fuel. i ran a set of 39mm pwk's dry with my 10mm cub one time. bought billet bowls and it never happened again. and that was on gas. Quote Link to comment Share on other sites More sharing options...
yamaha11 Posted February 19, 2010 Report Share Posted February 19, 2010 i have 35mm on my 4mm dune port from hjr and i think 35mm would be to big. 33mm maybe perfect Quote Link to comment Share on other sites More sharing options...
sheefreak Posted February 19, 2010 Report Share Posted February 19, 2010 If you got the money for unnecessary items, spend away! He won't run those bowls dry w/stock cyl. port of any kind on gas. Quote Link to comment Share on other sites More sharing options...
Ieat4strokes Posted February 19, 2010 Report Share Posted February 19, 2010 Save yourself some money. You don't need straight cut gears and you don't need billet bowls for gas. If you are just building extra for a future build fine, but you don't need those items. For a more trail built bike I would be looking at the 30-33MM range for carbs. I second this, i ran trails and 28 pwks worked well for me.... but with your 4 mill and etc id be looking at 30-33's as well.... Quote Link to comment Share on other sites More sharing options...
crazyj789 Posted February 19, 2010 Author Report Share Posted February 19, 2010 This is great advise thanks alot guys I believe Im going to go with 33's and billet bowls. I have plenty of money so we all like a little bling Im going to be running 100 octane Leaded race fuel in this 32:1 with klotz RD50 Quote Link to comment Share on other sites More sharing options...
Bill Posted February 19, 2010 Report Share Posted February 19, 2010 I basically have the same engine your building and im still rockin the stock carbs,it runs dam good! Im sure I could get more power with some aftermarket carbs,28s would be my choice in the future. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted February 20, 2010 Report Share Posted February 20, 2010 I agree, the straight-cuts aren't needed for your build. I'd go 33 or 35pwk for the carb. On a 4mil on gas you will probably be fine with the stock bowls. On my 10mil cub I sucked the bowls dry on gas just like loco, but on a 4mil on gas you should be good to go with factory bowls. - Jared Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted February 20, 2010 Report Share Posted February 20, 2010 If you got the money for unnecessary items, spend away! He won't run those bowls dry w/stock cyl. port of any kind on gas. I have a 4mil dune port and my shit head friend ran my bowls dry. 6th gear wfo down the highway will do it, I've seen it happen. I vote for 33 pwks. Quote Link to comment Share on other sites More sharing options...
Thewhite Posted February 20, 2010 Report Share Posted February 20, 2010 In the past, I ran some PWK 28mm and I got the dry bowl issue when I did 2 to 3 hard pass from 1 to 6 gear at WOT. I bought a pair of PWK 33 last month, will see this summer. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted February 20, 2010 Report Share Posted February 20, 2010 This is great advise thanks alot guys I believe Im going to go with 33's and billet bowls. I have plenty of money so we all like a little bling Im going to be running 100 octane Leaded race fuel in this 32:1 with klotz RD50 If you want bling send me your carbs and bowls and other things if ya like:) Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted February 20, 2010 Report Share Posted February 20, 2010 (edited) 28mm carbs and switch to a mid tension reed petal on a stock cage. Run a cool head with about 175-180 psi compression. Don't need big bowls or billet gears. Also lighten the flywheel, and run a dyna cdi, with a stock timing plate. Run wiseco pistons also. Edited February 20, 2010 by Snopczynski Quote Link to comment Share on other sites More sharing options...
