locogato11283 Posted February 7, 2010 Report Posted February 7, 2010 keep in mind the 7mm and 10mm are the same money. so go with the bigger. Quote
BluBanshee98 Posted February 7, 2010 Author Report Posted February 7, 2010 keep in mind the 7mm and 10mm are the same money. so go with the bigger. Definitely!!!! Quote
sandman81 Posted February 8, 2010 Report Posted February 8, 2010 Hp doesn't mean shit if you can't get it to the ground. When it comes down to drag racing EVERYTHING needs to be set up right. Ive raced against a stock ported banshee on alky and i have trouble beating him. But he has override, lockup, gearing and paddle size dialed down. Vs 421 cub that doesn't have a override or a lockup. Even the number of paddles makes a defference. We've ran a stock jug 4mill with 9 and 10 paddles and the 10 paddles made a big difference. What come into play when drag racing, other then high hp numbers lockup vs non lockup override vs non override swingarm length (to long can be just as bad as to short) shock (rebound and compresion) gear ratio tire size( includes 9,10,11 paddle and so on) weight ( includes riders fat ass) 1 Quote
kolb02 Posted February 8, 2010 Report Posted February 8, 2010 Hp doesn't mean shit if you can't get it to the ground. When it comes down to drag racing EVERYTHING needs to be set up right. Ive raced against a stock ported banshee on alky and i have trouble beating him. But he has override, lockup, gearing and paddle size dialed down. Vs 421 cub that doesn't have a override or a lockup. Even the number of paddles makes a defference. We've ran a stock jug 4mill with 9 and 10 paddles and the 10 paddles made a big difference. What come into play when drag racing, other then high hp numbers lockup vs non lockup override vs non override swingarm length (to long can be just as bad as to short) shock (rebound and compresion) gear ratio tire size( includes 9,10,11 paddle and so on) weight ( includes riders fat ass) Your very right! Quote
locogato11283 Posted February 8, 2010 Report Posted February 8, 2010 i agree. setup is key.. but having the 10mm cub doesnt hurt either Quote
BluBanshee98 Posted February 9, 2010 Author Report Posted February 9, 2010 Hp doesn't mean shit if you can't get it to the ground. When it comes down to drag racing EVERYTHING needs to be set up right. Ive raced against a stock ported banshee on alky and i have trouble beating him. But he has override, lockup, gearing and paddle size dialed down. Vs 421 cub that doesn't have a override or a lockup. Even the number of paddles makes a defference. We've ran a stock jug 4mill with 9 and 10 paddles and the 10 paddles made a big difference. What come into play when drag racing, other then high hp numbers lockup vs non lockup override vs non override swingarm length (to long can be just as bad as to short) shock (rebound and compresion) gear ratio tire size( includes 9,10,11 paddle and so on) weight ( includes riders fat ass) I understand this. I strictly started this thread to figure out what motor I want to build. This was not a chassis thread nor racing. I guess everyone reads a post and translates it into what they think it should be. I didn't start this thread for the "my quad is faster than yours" results! If I get the hp I want I can build the banshee around this. Like I said at the start of this...."Its a project"! Quote
papa_smurf49319 Posted February 9, 2010 Report Posted February 9, 2010 i dont think he was being hostile towards you, just saying that if your on a budget maybe your money might be spent elsewhere on chassis parts, suspension, etc and then youll be setup for your dream motor. Now if your like me you build the baddest mofo that you can afford and then find the weak links by breaking them lol Quote
BluBanshee98 Posted February 9, 2010 Author Report Posted February 9, 2010 I agree...the heartbeat of your bike is the engine. So if the engine is strong then you will have to compensate with the things that he mentioned. Quote
sandman81 Posted February 9, 2010 Report Posted February 9, 2010 I read the post right, you mentioned something about going out and using it on weekends to shoot up the hill and win some, plus you wanted to know about what has higher hp. So i just wanted to make sure you understood that hp number and setup go hand and hand. Everything i had mentioned to you is some thing that should be taken into consideration and even more of since you mentioned the cost of these builds. Better i know you know then i assume you know. As for that 520 super cub your talking about, i think i know the one, is it from rdz. They claim 114hp, im gonna assume but i would think its with there pipes, also is it on alcohol or race fuel. They also have a 421 non ported for 1,600, ported and it should be at 112hp but again is that alcohol or race fuel. I find it hard to believe that its on race fuel. Like Tyler said (loco) 7mil and 10mil are the same money. Quote
XxMeltIcexX Posted February 9, 2010 Report Posted February 9, 2010 I read the post right, you mentioned something about going out and using it on weekends to shoot up the hill and win some, plus you wanted to know about what has higher hp. So i just wanted to make sure you understood that hp number and setup go hand and hand. Everything i had mentioned to you is some thing that should be taken into consideration and even more of since you mentioned the cost of these builds. Better i know you know then i assume you know. As for that 520 super cub your talking about, i think i know the one, is it from rdz. They claim 114hp, im gonna assume but i would think its with there pipes, also is it on alcohol or race fuel. They also have a 421 non ported for 1,600, ported and it should be at 112hp but again is that alcohol or race fuel. I find it hard to believe that its on race fuel. Like Tyler said (loco) 7mil and 10mil are the same money. Armando's bike is the fastest bike I've ever seen.... Quote
sandman81 Posted February 9, 2010 Report Posted February 9, 2010 Armando's bike is the fastest bike I've ever seen.... Hahahahahahaha, we got jokes. Quote
sandman81 Posted February 9, 2010 Report Posted February 9, 2010 As for that 520 super cub your talking about, i think i know the one, is it from rdz. They claim 114hp, im gonna assume but i would think its with there pipes, also is it on alcohol or race fuel. My bad those numbers are for there 4mil super cub. not the 520 super cub Quote
BluBanshee98 Posted February 10, 2010 Author Report Posted February 10, 2010 My bad those numbers are for there 4mil super cub. not the 520 super cub Thanks for the info sandman! Didn't mean to get hostile!! I think I am gonna stick with the 10 mil cub! Considering the last thing at the dunes was a 4 mil dune port this should be a step up to one hell of a ride! Quote
sheefreak Posted February 10, 2010 Report Posted February 10, 2010 Thanks for the info sandman! Didn't mean to get hostile!! I think I am gonna stick with the 10 mil cub! Considering the last thing at the dunes was a 4 mil dune port this should be a step up to one hell of a ride! You will shit purple twinkies the first time you ride it if that is what you are coming from You will love a 10 cub, they are bullet proof motors and run very hard. All of Rob's(RDZ) dyno numbers will be w/alcohol unless he states otherwise. Quote
BluBanshee98 Posted February 11, 2010 Author Report Posted February 11, 2010 You will shit purple twinkies the first time you ride it if that is what you are coming from That's awesome! Can't wait....I've never shit purple twinkies before! LMAO Thanks for your input! Quote
