broncbob Posted January 19, 2010 Report Posted January 19, 2010 Would I see any gain from having the cases ported on a 4 mill stock bore? Quote
BigRed350x Posted January 19, 2010 Report Posted January 19, 2010 It all depends on your whole setup, and how much porting is in the cylinders. But on average you can see 2-4hp from good case porting on just about any bike. Quote
broncbob Posted January 19, 2010 Author Report Posted January 19, 2010 The thought right now is a dune/hill shooter port from Herr, Noss cool head with recommended domes for pump gas at 5000' feet by Herr, 4 mill crank, pistons for the 4 mill, Chariot reed cages, Chariot intake, 32 MM Mikuni TM's with pods, and T5 pipes, maybe Sheer small bore in frame. Quote
duaneh Posted January 19, 2010 Report Posted January 19, 2010 go for it. Its good reliable cheap hp so why not. Quote
Drewski Posted January 19, 2010 Report Posted January 19, 2010 why the hell not, while your already in there. I did mine and that's amazing! Quote
bbcmudtruck Posted January 19, 2010 Report Posted January 19, 2010 Yes! Port match the cases. I felt a seat of pants difference and it just seemed to run better overall. Quote
cbn70 Posted February 21, 2010 Report Posted February 21, 2010 Yes! Port match the cases. I felt a seat of pants difference and it just seemed to run better overall. How do you do that. use the base gasket as a template. Quote
cbn70 Posted February 21, 2010 Report Posted February 21, 2010 is there enough material there to take out enough to get it to match up properly. Does anyone have any pics Quote
