Ok I just bought my Shee, barely able to ride it when the sun went down, but I know for sure, the first thing Im going to investigate is, how difficult the stickers will be to take off. Any ideas to make it easier? My plan of action was to first attempt to peel them, then use Goo Gone on the remaining, if that doesnt work, Im going straight to the power washer. If anyone has anything that will make this easier, gimme a shout
A good trick is to heat it from the back side of the plastic with the heat gun. You want to try and heat the glue more than the sticker itself. The more glue you get to come off with the sticker the easier.
Car wash. Cold high pressure takes the sticker off, then high pressure warm to get the goo off.
Skip the goofoff, it can melt some plastics. Just ask my brother what happened when you try and clean the frames of Oakley gas cans!
like everyone else said, heat for the sticker. WD40 works well, but i use lighter fluid for any adhesive residue.
  • 2 weeks later...
