CUSTOM YAMAHA BANSHEE FRAME WITH UPPER AND LOWER CONTROL ARMS. FRONT SUSPENSION HAS BEEN MODIFIED FOR YFZ450 SHOCKS AND CONTROL ARMS. SHOCKS ARE NOT
INCLUDED WITH THIS, JUST WHAT IS IN THE PICS. WITH THIS MODIFICTATION, THE FRONT SUSPENSION IS 49" WIDE WITH STOCK YFZ450 CONTROL ARMS. NO SPACERS OR AFTERMARKET
CONTROL ARMS ARE NEEDED TO WIDEN THE BIKE. ALL WELDING HAS BEEN PROFESSIONALLY DONE. FRAME IS 100% STRAIGHT AND HAS NO CRACKS. FRAME HAS BEEN POWDER COATED AT
CUSTOM POWDER COATING OF DALLAS, THEYVE DONE WORK FOR OCC. IT HAS 2 LAYERS OF BLACK WITH 2 LAYERS OF CLEAR. ALL BEARINGS AND SEALS ARE NEW IN BOTH UPPER AND LOWER CONTROL ARMS. STEERING
STEM BEARING AND SEALS ARE NEW ALSO. FRAME HAS SCUFF MARKS WHERE SKID PLATE WAS MOUNTED, OTHER THAN THAT POWDER COAT IS PERFECT. BIKE HAS 6 RIDES TOTAL. MUST SEE
SHOW FRAME. $750 FIRM. IF INTERESTED CALL STEVE 972-880-0114
you can put 450 a-arms on without cutting and weld frame brackets and you also need 450 spindles to make suspension work right
WOW, or I could buy a whole banshee for that... Not to be a dick man, but do some research before listing an outrageous price like that.
Good luck with the sale..
I figured some others might chime in on this post.Dont the +plus 2 a-arms for the shee handle better than 450 a-arms
I appreciate all the comments. its actually two layers black and two clear like what it says. this is a frame for someone that wants quality. sure there are banshees out there for 750 i guess but there not gunna be all that great. Im not a banshee guy i race motocross but fox floats and this frame would be pretty nice considering lsr sells them w/ out powdercoat for 500.
WOW. UMMM Ya thats all I can say. Must be new too the banshee thing and not know that alot of peeps bolt on the yfz stuff all the time. I just bought a perfect pc blue frame for $85.
$250 too pc a frame! EEEEKK!!
Good luck on the sale. I got dibs if price drops too $225
a bit pricey. I just had everything on the bike powdercoated, except the front arms for $290, and the job was excellent.
swinger
brake, sprocket, and wheel hubs
carrier
cases
motor mounts
pegs
spindles
skid plate
