hauser2169 Posted October 3, 2009 Report Posted October 3, 2009 so i finally got a set of ported cylinders. put them on let it idle for a bit, re tourqed all the head and just nuts. i wasss going to do a plug chop to see about jetting. but when i went to take off it wont even rev prob pass 5 grand. it will not get in the powerband what so ever. i know it has something do wwith the reeds. could it be fuel as well? thanks Quote
bansheeseat$$ Posted October 3, 2009 Report Posted October 3, 2009 If your running stock carbs make sure you got the slides in the correct carbs and the choke tube is in place between the carbs. Quote
2rods racing Posted October 3, 2009 Report Posted October 3, 2009 so i finally got a set of ported cylinders. put them on let it idle for a bit, re tourqed all the head and just nuts. i wasss going to do a plug chop to see about jetting. but when i went to take off it wont even rev prob pass 5 grand. it will not get in the powerband what so ever. i know it has something do wwith the reeds. could it be fuel as well? thanks make sure your tors system isnt stuck on causing the enginre not to rev Quote
hauser2169 Posted October 4, 2009 Author Report Posted October 4, 2009 Is the parking brake on? PARKING BREAK AND TORS ARE DELETED. I JUST GOT A CHANCE TO DO A COMP TEST ON IT TONGIHT AND IT CAME SHY OF 50PSI THE PISTON LOOKS GOOD, MAYBE RINGS ARE SHOT. IM JUST GUESSING THAT MAY BE THE PROBLEM? IT WILL START UP IN 2 KICKS, HAS A ROUGH IDLE AND IF GET IT TO ABOUT 5000 RPM'S IT WILL START BACK FIRING. I DUNNO I NEEED TO TAKE A BREATHER PS SORRY ABOUT THE CAPS LOL JUST RELIZED IT Quote
volcrano Posted October 5, 2009 Report Posted October 5, 2009 PARKING BREAK AND TORS ARE DELETED. I JUST GOT A CHANCE TO DO A COMP TEST ON IT TONGIHT AND IT CAME SHY OF 50PSI THE PISTON LOOKS GOOD, MAYBE RINGS ARE SHOT. IM JUST GUESSING THAT MAY BE THE PROBLEM? IT WILL START UP IN 2 KICKS, HAS A ROUGH IDLE AND IF GET IT TO ABOUT 5000 RPM'S IT WILL START BACK FIRING. I DUNNO I NEEED TO TAKE A BREATHER PS SORRY ABOUT THE CAPS LOL JUST RELIZED IT ouch-that sucks dude!!i would say thats definately your issue.when u built it were the pistons tight in the bore??how long do u have since build?id still have to believe u would have alot more compression than that even if the rings havent fully seated.any cooling issues??bubbles in overflow?? Quote
Rodneya Posted October 5, 2009 Report Posted October 5, 2009 How did you check compression. At 50 psi it should take a couple hundred kicks to start if it ever starts. Quote
shogs Posted October 5, 2009 Report Posted October 5, 2009 Did you tear it apart, remove tors, then put it back together? Thats what I did and I accidentally cut a wire that wouldn't let it rev passed like 1/4 throttle before it backfired bad. Did you cut tors or remove it from the carbs as well. Try to be as descriptive as possible so people can help you out a little more. Quote
hauser2169 Posted October 6, 2009 Author Report Posted October 6, 2009 How did you check compression. At 50 psi it should take a couple hundred kicks to start if it ever starts. i took one plug out. put my compression tester on it and kicked it about 30 times till the needel stoped moving. and i did it while it was cold cause it didnt want to fire Quote
