i got a 421 cheetah cub with 22cc domes in it.. i run c12 racing fuel in it, not a 50/50 mix.. i was wondering if the compresion would change if i put 21cc domes in..? and if i would get more power..?
hate to hijack your tread,but were you at pismo this weekend?I raced a bike that looked alot like the one you have pictured there.
yes i was at pismo...i went sunday.. i was there only for the day... what bike were you running??
oh and my compresion if i could remember was around 165..
so who won???????
It'll probably raise you compression to around 180 or so PSI.
What is your timing at? Don't be afraid to crank up that timing.
With race fuel and the domes you have I'd be going 9 to 10 on timing...
I had the Blue banshee.Black and white jersey,tan pants,fox blue/white helmet.We raced a couple of times.Not to be rude but if you are running a 421 cub,my bike is running extremely well.
my timing is at +4. an wow i didnt know ican go that high on the timing.. thanks everyone for all the info... and jonny yes your bike was running crisp... i got a brand new topend and i was there to jet the bike... but it kinda ran like crap.. and i lost a pod out there so i got to tear down the topend and make sure everything looks good.. hopefully its all good..
Cubs love timing and compression.
Put 21 cc domes in it. Put the timing at 7 to begin with.
Should be a very noticeable difference.
You will probably have to richen up the jetting a size.
More compression and timing cause more heat....need more fuel to cool that.
