bobdryerr Posted September 3, 2009 Report Posted September 3, 2009 As a lot of you on here that have been reading my other posts on here I bought an 89 shee for 400 bucks an its now my project baby. So I'm down to the last 2 things top end rebuild an carbs. So my question is in my position she I bore her to the 60 over or should I resleeve her. I'm debating on both cause vitos has that stock rebuild for 80 bucks but then I was thinkn bout boring to 60 over an gettin super stock rebuild kit for more power to go with my exhaust an filter setup. What would all of you do. All opions are welcome. I'm open minded to all options. I'm trying to build the quad for fast trails an a few slow trails but not to many slow ones. Quote
shawn941 Posted September 3, 2009 Report Posted September 3, 2009 imo i would bore it,,,might wanna get it trail ported since you already got it apart Quote
bobdryerr Posted September 3, 2009 Author Report Posted September 3, 2009 imo i would bore it,,,might wanna get it trail ported since you already got it apart Where could I get the port job done an if I did that would it need special pistons? Quote
jbooker82 Posted September 3, 2009 Report Posted September 3, 2009 Where could I get the port job done an if I did that would it need special pistons? Stick with Wiseco pistons. A port job is a great power increase. It is just as noticable as going from stock pipes to aftermarket. They opean up the ports in the cylinders. This changes when the air and fuel come in and exhaust goes out. It is like putting a cam shaft in a 4 stroke. I would stick with a reputable BANSHEE builder since there is more to it than hogging the ports out. Jeff at FAST is a good guy to deal with. Call and talk with him, he will get you fixed up. Your jugs will come back ported and new bore and pistons ready to install. www.farmandsandtoys.com Quote
uwenr Posted September 4, 2009 Report Posted September 4, 2009 As a lot of you on here that have been reading my other posts on here I bought an 89 shee for 400 bucks an its now my project baby. So I'm down to the last 2 things top end rebuild an carbs. So my question is in my position she I bore her to the 60 over or should I resleeve her. I'm debating on both cause vitos has that stock rebuild for 80 bucks but then I was thinkn bout boring to 60 over an gettin super stock rebuild kit for more power to go with my exhaust an filter setup. What would all of you do. All opions are welcome. I'm open minded to all options. I'm trying to build the quad for fast trails an a few slow trails but not to many slow ones. bore it and wiseco pistons Quote
