RippinShee Posted September 14, 2009 Author Report Posted September 14, 2009 So I will need new gaskets for the reeds and all? So even if I get reed spacers, they wont hurt anything right? Quote
bbcmudtruck Posted September 14, 2009 Report Posted September 14, 2009 You will need new reed gaskets (4) and gaskets for the spacers (2). I really don't think reed spacers have that much effect on performance. The main reason people run them is to clear the clutch arm with the left carb bowl. Your upp intakes may be angled to fix that problem though. Who did you order them from? Quote
RippinShee Posted September 14, 2009 Author Report Posted September 14, 2009 HAHA. I ordered them from Amazon. I had a gift card, I kno I kno. Quote
3SGTE Posted September 15, 2009 Report Posted September 15, 2009 (edited) I use that with my pwk 35mm I need reed spacer it's hard to place boost bottle with clip... maybe just put screw in the hole is best thing to do Edited September 15, 2009 by 3SGTE Quote
dajogejr Posted September 15, 2009 Report Posted September 15, 2009 I have UPP, I had boss. I have the UPP without any holes for the crossover tube. I haven't used one in years. Yes, you'll need reed spacers unless you want to bend down your clutch actuator arm and grind off some of the drain plug bolt for the carb. Otherwise, it will hit. And as said, just because it's new, doesn't mean it won't leak. I use a thin coat of RTV on both sides of ALL the gaskets. The spacers won't effect performance. Keep in mind the intake/reed cage is part of the overall combustion chamber and need to be sealed correctly. Quote
pr0blumz Posted September 15, 2009 Report Posted September 15, 2009 I have UPP, I had boss. I have the UPP without any holes for the crossover tube. I haven't used one in years. Yes, you'll need reed spacers unless you want to bend down your clutch actuator arm and grind off some of the drain plug bolt for the carb. Otherwise, it will hit. And as said, just because it's new, doesn't mean it won't leak. I use a thin coat of RTV on both sides of ALL the gaskets. The spacers won't effect performance. Keep in mind the intake/reed cage is part of the overall combustion chamber and need to be sealed correctly. I bent the clutch arm down on my motor and haven't had any problems yet. Quote
