robert0762 Posted July 27, 2009 Report Posted July 27, 2009 (edited) What can I do to keep the motor from turning while I take the flywheel nut loose. I dont have a holder and the motor is outof the frame already. The sprocket nut and clutch bos nuts also. I am just trying to get it apart so it can go back together . I should have ordered one with my parts but was not thikin Edited July 27, 2009 by robert0762 Quote
278 Posted July 27, 2009 Report Posted July 27, 2009 put it on the ground and put your foot on the cases. that's what i did Quote
RZBansheeMan Posted July 27, 2009 Report Posted July 27, 2009 Use an impact, they come off real quick. Quote
robert0762 Posted July 27, 2009 Author Report Posted July 27, 2009 put it on the ground and put your foot on the cases. that's what i did Need to keep it from spinning Quote
Jokerzwild Posted July 27, 2009 Report Posted July 27, 2009 i just changed my timing plate yesterday, if you use an impact on the flywheel it wont spin mine was realy tight i had to us pb spray on it and let it soak for acouple hours and it came right off :biggrin: Quote
patrickkomar Posted July 28, 2009 Report Posted July 28, 2009 Use a shop rag and let it wind between the output gear on the crank and input gear on clutch hub. Works! and wont damage any thing. Quote
350scabarat Posted July 28, 2009 Report Posted July 28, 2009 Its pretty easy. . .try get a screwdrive thats shaft is square, a round1 will do but square is easier. . .now on the outside of the flywheel there are 2 pickups. Put the screwdrivers shaft next2 on ane the point u push in the case. . Theres 3 plases it would hookup. Just be carefull not to let it slip. . Itl damage the pickup. As 4 the boss take old friction plates, about 4. Then put on boss. Clamp them. .drill 3 holes. Bolt 2 of them, put a bicycle cable in the 3rd hole. Now slide it on the boss and tie the cable sumwhere and then turn the nut off. I tied the cable on my frame bt urs is out. . So gdluck. Quote
VegasJeff Posted July 28, 2009 Report Posted July 28, 2009 Its pretty easy. . .try get a screwdrive thats shaft is square, a round1 will do but square is easier. . .now on the outside of the flywheel there are 2 pickups. Put the screwdrivers shaft next2 on ane the point u push in the case. . Theres 3 plases it would hookup. Just be carefull not to let it slip. . Itl damage the pickup. As 4 the boss take old friction plates, about 4. Then put on boss. Clamp them. .drill 3 holes. Bolt 2 of them, put a bicycle cable in the 3rd hole. Now slide it on the boss and tie the cable sumwhere and then turn the nut off. I tied the cable on my frame bt urs is out. . So gdluck. WOW! Quote
No Limit Powersports Posted July 28, 2009 Report Posted July 28, 2009 Use a impact and put your hand on the socket and hold it as you impact it and it wont spin. Quote
robert0762 Posted July 28, 2009 Author Report Posted July 28, 2009 Thanks for all the help guys got lucky and the shop had one that thedidnt know they had (clutch holder) Quote
