hauser2169 Posted July 21, 2009 Report Posted July 21, 2009 k so my gear on the very back of the clutch basket keeps blowin up. this is the second time this happend? any ideas how this could be cause? Quote
hauser2169 Posted July 21, 2009 Author Report Posted July 21, 2009 k so my gear on the very back of the clutch basket keeps blowin up. this is the second time this happend? any ideas how this could be cause? anyone feel free to chime in Quote
FASTOYS Posted July 21, 2009 Report Posted July 21, 2009 "Blowin up"?? Are you talking about the kicker idler to the rear of bike behind basket??? Can you show a pic of what you mean? Quote
hauser2169 Posted July 21, 2009 Author Report Posted July 21, 2009 "Blowin up"?? Are you talking about the kicker idler to the rear of bike behind basket??? Can you show a pic of what you mean? yes the gear on the back of the clutch basket keeps gernading. its the second time its happend i say in 2 months. sorry no pic. stuck in class all night Quote
hauser2169 Posted July 21, 2009 Author Report Posted July 21, 2009 "Blowin up"?? Are you talking about the kicker idler to the rear of bike behind basket??? Can you show a pic of what you mean? is there a stronger clutch basket out there i can buy besideds oem. ? i really dont no what is cuasing this Quote
spurdy Posted July 21, 2009 Report Posted July 21, 2009 is there a stronger clutch basket out there i can buy besideds oem. ? i really dont no what is cuasing this The new clutch basket will require the use of that gear. If I understand right this is the gear that engages with the kicker? If so, maybe the kicker is not staying in position as it should. Or maybe your clutch shaft is bent???? I can't really see that but I ain't looking at it. Good Luck SP Quote
hauser2169 Posted July 22, 2009 Author Report Posted July 22, 2009 The new clutch basket will require the use of that gear. If I understand right this is the gear that engages with the kicker? If so, maybe the kicker is not staying in position as it should. Or maybe your clutch shaft is bent???? I can't really see that but I ain't looking at it. Good Luck SP should i jsut by a new gear that goes to the kick start? thats where the 2 touch. if that makes sence>> Quote
SheeBang92 Posted July 22, 2009 Report Posted July 22, 2009 is the gear miscolored like does it have a blueish tint to it if so it is getting hot and losing its temper and just shattering are you using the correct weight oil? Quote
ToomeySheeLE Posted July 22, 2009 Report Posted July 22, 2009 Either something is horribly misaligned or theres a bent shaft.. that just shouldnt happen under any Normal cirrcumstances.. deal it Quote
hauser2169 Posted July 23, 2009 Author Report Posted July 23, 2009 i think i do have a bent shaft. i took it apart today and i had to put a 2 jaw puller on the basket to get it off. i then had to take the gear to the very right of the basket off which i belive is to the coolant impeller? i then had to mesh the 2 gears together perfectly to get them both on. it was NEVER this hard to take it apart. are the shafts expensive and im guesssing i obviously have to split the cases correct? Quote
hauser2169 Posted July 23, 2009 Author Report Posted July 23, 2009 i think i do have a bent shaft. i took it apart today and i had to put a 2 jaw puller on the basket to get it off. i then had to take the gear to the very right of the basket off which i belive is to the coolant impeller? i then had to mesh the 2 gears together perfectly to get them both on. it was NEVER this hard to take it apart. are the shafts expensive and im guesssing i obviously have to split the cases correct? TTT Quote
J-Madd Posted July 23, 2009 Report Posted July 23, 2009 That gear is never engaged to anything except when kicking it. What do the other gears look like (on the basket and primary gear on the crank [behind water pump drive gear])? If the shaft was bent, I'd think you would have bad wear on those gears. Are installing both thrust washers, and bushing correctly? Quote
hauser2169 Posted July 24, 2009 Author Report Posted July 24, 2009 That gear is never engaged to anything except when kicking it. What do the other gears look like (on the basket and primary gear on the crank [behind water pump drive gear])? If the shaft was bent, I'd think you would have bad wear on those gears. Are installing both thrust washers, and bushing correctly? my primary gear looks fine. its only the gear that goes all the way around the clutch basket and dircectly behind the basket is messed up. when kicking the motor, the small gear to the left that binds with rear gear on the basket is a little messed up. if that makes since. Quote
