Brass or Plastic?
The plastic ones suck, your probably gonna ruin them.
For the brass ones I use a long brass punch and kinda get them on an angle on the edge of the bushing. If you beat around the edge they should slide out. Sometimes they come out easy, sometimes, I ruin them.
EDIT: by the way, the bikes looking super sick bro, I still gotta try and make it up there to go ridin with yall. I dont do much hillclimbing, but I heard theres some pretty sick trails up there.
I use a a flattened punch and hit them from the opposite side, but you can use any long-skinny object that wont chinger up the bushing. I'm not relating that in any other way but with tools :biggrin:
Plastic ones... They are shot anyways and the ones I removed I am just destroying them. But it is taking too long.
Yeah, fuck it then, your best bet is to trey to break them with a hammer and a long common screw driver and pull them out.
X2 with meltice,
on the lowers use a punch that doesn't have any sharp edges, come through the inside and tap it out from the other side, just make sure not burr or scar the inside of the arm mount. uppers are just a bitch, plain and simple.
Center punch idea worked like a charm feelas! Got 10 of them out in the time it took me to take the first 2 out!
Thanks guys!!!
Gees, wth method were you using? Always resort to the "hit it harder with something bigger" tactic before anything else.
