  • Replies 30
  • Created
  • Last Reply
Top Posters In This Topic
Your going to get a million opinions on this man. Everyone runs/likes something different. Some like 10w30 motor oil some like ATF type F oil some like Bel ray gear saver 80W, some like Motul 2 stroke gear box oil and there's a ton more brands and weights out there to run.
Find what YOU like and run it.
I run bel-ray gear saver 80W, because i can get it cheep at my buddies shop and its been good too me and works great. I change it 2 times a season, once at the start and once in the middle, no problems.
Edited by savage420
ok so i am looking to change my oil in the banshee. What oil is recommended, and what's the best oil to use for a banshee's tranny
Like already said, everyone is going to like something different. I run Klotz SuperTechniplate @ 40:1 and ATF type F in the tranny.
i use amsoil 10. 40 and they recommend 0. 40. Although I'm looking for a better oil.
i run amsoil dominator @ 70:1 and its okay. Marcus
Wow I run 50:1 Ams oil. Have you had any issues with 70:1?
Crisco
Dammit...you stole my idea.
Fine...I'm switching.
Non-trans fat frying oil...:)
Anything you want you can put in there damn near. I was told by the guy that cut my transmission to run ATF Type F, so that's what I run.
After running it for over two years, well over a thousand passes on the bike, the tranny and all gears, forks, drum, etc., looked great. So great I put it back in the same it came out.
I do change mine after every other event, and use a magnetic drain plug as well.
I use only Klotz Supertechniplate in mine. There aren't a LOT of oils that mix with methanol, this is one of them.
How much oil does it hold? Sorry, I don't have a manual and cant seem to locate the answer either here nor on Google. :blink:
LOL! It says right next to the dipstick molded in the cast clutch cover! 1500 ml.
