i have recently purchases a boss 8 plate clutch basket and hub but my stock pressure plate does not fit the hub. bo i need a boss pressure plate to? i also have a direct drive lock up on it. any sugjestions? thanks
What are you running that you need an 8-plate AND a lockup? Why not just run a stock width billet basket and a lockup?
Word.
You need to have a pretty healthy engine (more than 150hp) to overcome the capabilities of an OEM'ish clutch with a lockup.
If you didn't want to run a lockup, then an aftermarket 8 or 10 plate system probably makes sense. However, I would still prefer a lockup over these systems due to the fact that it's easier to get ahold of replacement clutch parts. :geek:
  • 2 weeks later...
+1.....
Trying to use what you have or what?
with the boss kit, you need the basket and inner hub, which you have.
When you say the pressure plate doesn't fit, have you tried turning it to see if it'll match up? I have to do with stock.
Otherwise, contact who you purchased the clutch kit from and/or BOSS Themself and ask for their advice....
you should be able to run the stock pp or the boss one
i ran the hinson one then put my stock one back on when i put a lock up on my 8 disk.
like dave said you probably need to time it in the correct groove.
