nitrocircus
Everything posted by nitrocircus
  1. I have a nice set of PC I'll get pics if u want them
  2. I have a 421 cheetah cub by redline. Right now I have a nice pair of pc pipes on it looking to upgrade would like to trade also can have cash on top of my pipes
  3. so u recommend pump gas over race fuel? i like he 110 idea because i have it easily avalible and the people i ride with also run it.
  4. that's what i was kinda thinking but was told the lead and oil in race fuel is good for a engine. i just checked out redline I'm going to go with them, it looks like lots of menbers here have good things to say about them. so what cc should i go with for 92 octane i also have a adjustable stator plate for timing?
  5. this says clean up porting but i will check it out.
  6. ebay! http://www.ebay.com/itm/Banshee-421-68mm-4-mil-4mm-Cheetah-Cub-Cylinder-Top-End-Big-Bore-Kit-Domes-Oring-/201466177492?hash=item2ee851e7d4:g:3eUAAOSwLzdWRNIM&vxp=mtr
  7. lol who is that? the domes come with the kit so i need to know prior to ordering
  8. ok my stock cylinders are trashed, so I'm going with a 421 cheetah cub. I plan on ordering it this weekend but am lost on what dome size I should get with it. i was told if i set it up for race fuel i could get more life out of the top end. is that true? we have 110 avalible at the pump but what size domes should i get for 110. otherwise we have 92 at the pump. what do u guys recommend i do?
  9. tors and brake are all eliminated. I haven't done a leakdown. I don't have a tester for that. I gaped the module with a business card. it has good spark and I even put fuel in the cylinders and nothing but a few pops.
  10. ok my banshee has spark, fuel, and compression. but will not start. when I built the motor I had to swap the plug on my stator to match my wire harness. it is a new rm 200w stator and the wires were different colors. could I have some wrong that would make it spark wrong and not run? it fires once and a while but just a pop and a lil puff of smoke. I was told that I wired my stator wrong and its firing at the bottom of the stroke is this true? and could anybody help me wire it correct?
  11. what grounds to the frame?
  12. i think it is not getting fuel in the engine. could this be my floats being out of wack? i know there is gas in the carbs but my plugs are dry? i have 34mm pwk's
  13. lol, ya i checked the tire pressure, that was my first guess. maybe i could check if all my stickers are in the right place also.
  14. wouldnt this all be good if i have good spark?
  15. RM stator but is has real strong spark and its set at +3
  16. alright i just finnished my banshee and i cant get it started. it has spark and fresh top and bottom end. i kicked this thing till i had a hole in my shoe it would fire like once but not start and a loud backfire every once in a wyle. any ideas? and after kicking it for so long the plugs still looked dry maybe not getting fuel? i know the carbs are full of gas becouse i can see the level in the dial a jet tubes.
  17. whenever i get on e-bay i always forget about the site sponsors. i also ordered a tm designworks case saver to go w/ it
  18. http://www.ebay.com/itm/251095463309?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D251095463309%26_rdc%3D1ok cool i ordered this kit off of ebay. i know i have a newer rear hub so i should be fine.
  19. ok i was shopping for a chain amd sprocket set today, and noitced a lot of places say (fits 89-up) I have a 87 engine and thought all year banshees had the same sprockets. is this true or not? mine has 6 spline shaft and i see pics w/ 13 spline shafts. can someone verify this for me?
  20. ok i am clueless on what jets to sart with on a new motor i built. here is what i got. 4mm long rod stroker, 66.5 bore, 22 cc domes, procircuit platnum pipes, 34mm pwk carbs w/ 6" k&n filters, stage 4 porting from some ebay store cant remember the name, my elevation is 1200ft. like i said i am clueless, i just need a place to start. any help would be appreciated. thanks
  21. i think i seen the ones u are talking about. i wanted to bid but low on cash now. post some pics of what they look like. are u using stock front?
  22. i have a stock set upper and lower let me know if interested.
