Guess the damage!!!!
24 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Lets see who can guess what the cause is.. lol (only way to keep positive thoughts... :confused: )
Ok i was racing a RM125 and a tired CR250 kickin ass of course... anyway i deside to get them out of the hole with some 2nd gear launches. First time went great put a quad length on the 125 before i hit 3rd... anyway second race i shift/slip/shift/slip... and the clutch cover is pretty warm... almost too warm. I was doin the mistake of coasting with the clutch pulled in to a stop. Its making a rattling noise when the clutch is pulled in and it only grabs when the clutch is close to full release. The clutch holds until the power kicks in. Its a Barnett Kevlar clutch with 6HD's with 20+ hours on it and i use belray 80w.
EDIT: the clutch is properly adjusted and i inspect it every other ride and change the fuilds as frequently as i can.
Edited by LIM_Whiteboy4life
sorry man the last one was to funny to pass up. but i hope you get it figured out. what happen when it just "went out"?
I would shift into the next gear (clutchless shifting) and pin it and all i would get is rev's and no pull... same in every gear.
Eh no big whoop. I just thought i could add some more FAQ issues to the clutch problem/symptoms and figure it out. I replaced the OE spring bolts with stainless ones w/ washers, longer also... helps make it an easier install. Well they backed out and caused the slipping issue, so im curing it overnight with some blue loctite and see how it holds up.
with them loose you didnt ride it too long and fry the clutch did you?
No not at all... as soon as the problem started i stoped check the fluid and told everyone that the bike is done for today and limped it back to the truck. It rode fine as long as i didnt get into it. I rode an 86' YZ 100 2 stroke for the rest of the day awsome bike lol
