My first banshee stock all the way except for k n filter. Do the bansees have absolutly no torque at all down low or should I be changing my jetting. I had to richen the needle one slot to get it to run good now plugs look good and she starts on 3 or 4 kicks . on my blaster i could put along at almost an idle clutch it a little and pop it right up the banshee wont do it at a low rpm i got to rev it good then she just wants to spin so should i jet or look into mods cause they just have no torque at all
it takes a while but thats pretty much how they are. you can do several things to improve them in the low end, but they'll never have the same response as a blaster unless you f''ckk up the jetting real bad
if your going to leave it stock, like stock pipes, then go one tooth smaller on your front sprocket, that'll gear it down some and help you out.
so does it have no low end or is it a problem with it not hooking up? if its bone stock, does it have the stock dunflop tires? they suck and probably wont hook up to save your life.
I have one stock Banshee and a Banshee with a T-5 pipe set on it.
Ill tell you that you will get bored with stock pipes really quick.
Use that clutch for more rev at low speeds.....lol
Its just wants to scream, dont hold it back ....lol
Let her rip :cool:
3-4 kicks, tells me the carbs are a little off. cleaning and tuning them will help the low end a bit, too. she should creep near idle like the blaster, but at a faster speed.
