RagunCajun Posted February 23, 2009 Report Posted February 23, 2009 atf type f 1.29 a quart at walmart +2 Quote
2001Stroker Posted February 23, 2009 Report Posted February 23, 2009 problem with atf type f is its viscosity, im not sure exactly what it is, it just says for wet clutches, whereas pay abit more and you have the perfect viscosity, great brand and designed basically especially for your banshee. Are you a Maxima dealer, or something? Why are you pressuring everyone to use what you're using? We all got our favorite oils. They all work. Quote
Misssppelllleddd Posted February 24, 2009 Report Posted February 24, 2009 I use Golden Spectro 80w gear lube. And how many times is this issue covered? Once a week or two weeks? Quote
3SGTE Posted February 24, 2009 Report Posted February 24, 2009 I always use Motul product and for trnsmission I use Transoil Expert 10w40 http://www.motul.com.au/product_line_up/gear_box/gear11.html Quote
swrbansheeboy Posted February 24, 2009 Report Posted February 24, 2009 this topic is as bad as what oil to mix your fuel with. everyone has there preferance of case oil and imo everyone is right, i've ran everything from name brand oils (bel ray, maxima, honda, dumonde tech) to not so name brand (atf, hyster hydraulic fluid) and all have worked for me. right now i'm running redline shockproof because of a little story my builder told me, it just happens to be my flavor for the time being. is it the best case oil? probably not, but it is working fine for me. just as all the other brands/atf's and regular motor oils are working for everyone else here. to me the bottom line is that the best case oil is the one thats working for you and keeps you from smoking your clutch & tranny, if your not breaking anything then the oil your using is just fine so theres no need to worry about what anyone else is running because your bikes doing great with whatever your running... i'm just suprised nobody's come in here pushing amsoil yet...lmao Quote
Koolguyson Posted February 24, 2009 Report Posted February 24, 2009 AFT kills my clutches. I use Motul in my race bikes, and cheap ol' Honda GN in bulk for the rest of the bikes. Quote
rubberneck Posted February 24, 2009 Report Posted February 24, 2009 problem with atf type f is its viscosity, im not sure exactly what it is, it just says for wet clutches, whereas pay abit more and you have the perfect viscosity, great brand and designed basically especially for your banshee. Are you aware that automatic transmissions are FULL of wet clutches. They look exactly like the clutch we use in bikes. Many late model manual transmissions and transfer cases in automotive aplications also use ATF. I dont see viscosity being an issue. I personally have been using honda for the last couple of years, but know a lot of guys that run ATF Quote
phxrider Posted February 25, 2009 Report Posted February 25, 2009 (edited) Bell Ray Gear Saver SAE 80W. Been using it for 3 years now with no problems. Edited February 25, 2009 by phxrider Quote
tony cub Posted February 25, 2009 Report Posted February 25, 2009 sticking to good old castrol 10w 30 Quote
Snopczynski Posted February 26, 2009 Report Posted February 26, 2009 Viscosity The SAE classification indicates the oil viscosity and is referenced by a number that appears in the center of the donut shaped logo. The higher the number, the thicker the oil. Thick oil has a high resistance to flow, which means a high viscosity. Oil classified with a Quote
lokisbuddy Posted February 26, 2009 Report Posted February 26, 2009 this topic is as bad as what oil to mix your fuel with. right now i'm running redline shockproof because of a little story my builder told me, it just happens to be my flavor for the time being. Lets hear that story bro. I run a 50/50 mix of breast milk and nestle quick in my tranny :yelrotflmao: Seriously I am going to be running amsoil type f or amsoil 10w30 (because the dealer is accross the street.) Quote
trex banshee Posted February 26, 2009 Report Posted February 26, 2009 o'rielly's type f.... :biggrin: stock tannies to overrides trannies 6 years no problems, 1 clutch. Quote
baudy Posted February 26, 2009 Report Posted February 26, 2009 Been using Yamalube Trans-Oil-PLus since new and never had any slippage problems at all.... Quote
smuttdawg Posted February 27, 2009 Report Posted February 27, 2009 4mill cheeta, :thumbsup: been running atf type-F for two years w/ no issues. Quote
