I can't recall ever having a heating issue when I was running the stock head. But my motor is not heavily modded either, though. Also, I usually ride mine in fast, open places where there is a lot of air going through the radiator. I don't know how it would do in tight trails.
I run a Noss head now.
no major problems if your just casualy riding but it can overheat alot quicker than if you have a coolhead/Billit impeller installed and your going through tight/technical/dirty/muddy shit or riding it for extended periods of time.
I also have a Nosshead and it is noticeably cooler over stock.
Overheated once and it was my fault. It was a long ride and I was sitting at idle for a while while waiting for another rider to get unstuck. I shut it off, let it cool, and even with a mud caked radiator in tight woods, did not over heat again. I did have the top hose blow a pin hole in it once damn that was hot.
Had a cool head, ditched it and went to a stocker. NO difference with my CRJ temp gauge. I do have a billet impeller.
Generally an overheating issue is related to something else not right, coolant flow, jetting etc. The stock cooling system works well if everything else is right. Not so sure I believe the aftermarket heads help cooling that much. But all things considered, a little insurance (oversized radiator, engine ice, billet impeller) is worth the money if you have a mint in a motor.
SP
And for the record man, a boost bottle will not improve performance on the shee, and did you guys note that they only showed vids of the banshee being spanked by dirt bikes and its predecessor? LQTMS
