thelegend702 Posted January 29, 2009 Report Posted January 29, 2009 sick of gettin smoked .want to put cool head and timing plate on my shee.do you guys reccomend a 2 piece og cool head or the new one piece styles,if so what brand do you use.also is 20mm the proper size domes to use with pump gas stock piped motor.the timing plate question is just what brand and where to get puller for flywheel.shaft looks pretty rusty so it probably wont be easy. thanks for your imput it is appreciated Quote
blaster2006 Posted January 29, 2009 Report Posted January 29, 2009 sick of gettin smoked .want to put cool head and timing plate on my shee.do you guys reccomend a 2 piece og cool head or the new one piece styles,if so what brand do you use.also is 20mm the proper size domes to use with pump gas stock piped motor.the timing plate question is just what brand and where to get puller for flywheel.shaft looks pretty rusty so it probably wont be easy.thanks for your imput it is appreciated im pretty sure its 21cc or 22cc.. depending on elevation... so if your high up 21cc would just be enough to run pump gas. thats just what ive heard for the cool head, yeah, why go with old style, go with the new style one piece.. Quote
Ieat4strokes Posted January 29, 2009 Report Posted January 29, 2009 nothing wrong with the older style cool head. i was actually told they run cooler because they are hollow on the inside and more of it is gutted? i dont know, just stating what i was told..... Quote
farmguy Posted January 30, 2009 Report Posted January 30, 2009 Chariot makes a nice head and timing plate Quote
harbinger of death Posted January 30, 2009 Report Posted January 30, 2009 you should get some pipes too. Quote
1.6i Posted January 30, 2009 Report Posted January 30, 2009 Hit up jeff at F.A.S.T for that timing plate and flywheel puller. good guy, fast shipping :thumbsup: Quote
2slow350 Posted January 30, 2009 Report Posted January 30, 2009 sick of gettin smoked .want to put cool head and timing plate on my shee.do you guys reccomend a 2 piece og cool head or the new one piece styles,if so what brand do you use.also is 20mm the proper size domes to use with pump gas stock piped motor.the timing plate question is just what brand and where to get puller for flywheel.shaft looks pretty rusty so it probably wont be easy.thanks for your imput it is appreciated Do you have aftermarket pipes?? If not, I would get get a set of pipes first if your getting beat without them.. And depending on ur elavation, 20cc domes would work on 91 octane.. Quote
