ok i installed chariot advance today, timing mark set at the 4th line from zero... +4 degrees. i aligned it with crack in case, set pickup using a buisness card and it will not fire. ive double checked and everything looks ok....just the way it was and still nothing. whats wrong!?
plug in stator? all my wires going to stator is soldered. i didnt have to unhook anything. just took out screws and moved it out the way to take off stock plate. then installed new advance plate and used stainless allenheads to secure everything back in place. would using stainless make it not ground? thats the only thing i changed. this is really confusing! its gotta be something small. is there any way pickup or stator couldve crapped out on me? ran fine before this.
i couldnt find gap feelers no where so i just used buisness card......so im not exactly sure. but its not firing at all, took out a plug and nothing. dumb question but is there any thing i couldve shorted out taking stator off? i thought i couldve swore i seen a spark when i was using pliers to take off the 3 screws holding stator in.... its not energized right? this stator concept is new to me as usually everything i deal with has a battery. i have a fluke meter what could i check and what readings should i look for? thanks again for all the help.
c'mon i know im not the only person in the world this has happened to....... how do i test the stator and pickup? could one have crapped out on me during timing plate install?
did you use a flywheel puller when removing the flywheel? dbl and trpl check the solder connections. dont over look dumb things like the kill switch in the right position and if you still have a key, that it is also in the correct position. make sure that the flywheel nut didnt come loose.
yes i used a flywheel puller, i dont have a key switch never had one since ive owned it. The on/off switch was in the on position. i still have tors, can i unplug it to disable it just to rule that out? if so can i just unplug at the tors controller close to the coil? i have a tors eliminator on the way..... but yes i suppose i put the key in the crankshaft right? it sits in the slot on shaft like a boat?
just dont understand why i wouldnt have spark. even if the timing was 180 off it would still spark.... something happened, this sucks ass.... had a big day planned tomm :(
ok, somthin happened, so now u have to find it. for you're first q, the stator, cdi side, wires are red/white, and green/white. should measure 13.7-20.5 ohms. the other 2 wires are the pickup to the cdi, but i can't remember what the measure. unplug the little tors box next to the coil, and make sure the black/white wire in the harness side plug has no continuity with ground. make sure the black wire does. the flywheel didn't rattle did it?
i would check your pickup connections.........when i got my shee the pickup gap was almost twice what the spec was but it still got spark and ran ok :confused: I would also check stator plug. it should be by your airbox, just trace the wires untill you find it.
If you go to the home page of this sight it has (tech docs) and in there you will find a great article that has all the specs and info you need to troubleshoot your electrical it's under (Banshee Electrical Faqs)
ok heres the rundown.... got me a manual from a friend. followed it to a T. usuing a fluke meter i got 111 from the pickup and nothing from stator..... also got 1 from primary side of coil and nothing from secondary (measuring caps from neg terminal on coil.... so is my coil and stator bad??? wtf
