MAICK Posted January 7, 2009 Report Posted January 7, 2009 ok so i was putting a new shift shaft in the banshee a while ago. i had the clutch out and i noticed if i grabbed the basket and the gear i could move each piece a little bit does this mean i need a whole new basket or is there some cushions i can get. Also so i had my banshee ported and stroked last winter. i had it ported for cpi pipes. (its got fmfs now) i also have a single carb. i need to get pipes and carbs but i dont know what to get first. any comments would be appreciated thanks Mike Quote
jbooker82 Posted January 7, 2009 Report Posted January 7, 2009 I would say a billit basket because your not supose to be able to move the gear on the basket. The coushins are shot and you cant replace them on the stock basket. Quote
AKheathen Posted January 7, 2009 Report Posted January 7, 2009 I would say a billit basket because your not supose to be able to move the gear on the basket. The coushins are shot and you cant replace them on the stock basket. yep it's shot, get new one, depending on what kind of power curve you want, i might go back to duals. do a search on poll results post, there is some graphs and an awsome writeup by snoop on the setups :thumbsup: Quote
MAICK Posted January 7, 2009 Author Report Posted January 7, 2009 (edited) yep it's shot, get new one, depending on what kind of power curve you want, i might go back to duals. do a search on poll results post, there is some graphs and an awsome writeup by snoop on the setups :thumbsup: cool ill have to get me one of those fancy billet ones yeah kevin from herr ported it last winter he told me i need duel carbs. i just didnt know what would be the better buy (for now). i got enough money to get the carbs and intake or the pipes right now. Edited January 7, 2009 by MAICK Quote
AKheathen Posted January 7, 2009 Report Posted January 7, 2009 cool ill have to get me one of those fancy billet ones yeah kevin from herr ported it last winter he told me i need duel carbs. i just didnt know what would be the better buy (for now). i got enough money to get the carbs and intake or the pipes right now. imo the power of the pipes and the power of the engine are a closer match, so you'd make way more improvement by doing the carbs first. Quote
MAICK Posted January 7, 2009 Author Report Posted January 7, 2009 cool. man thanks i dont know if this gets mentioned enough around here but you guys on this site are the shit. Quote
Troubledsol Posted January 7, 2009 Report Posted January 7, 2009 You can rebuild a stock clutch basket I put the hard ones in my stocker and my wife Blaster BUT you will need to be able to machine it all you do is grind off the 3 rivets pull it apart and rebuild it Put it back together re insert the rivet and weld them back Quote
bbcmudtruck Posted January 7, 2009 Report Posted January 7, 2009 Ask Kevin and see what he suggest you do. Quote
