WALMART LIGHTS 16 DOLLARS LOL... Bright as hell!!! I just need to make a mount for them... I might cut the stock light holder off and make a bracket for the new 1's... working on the bitch 2nite..
i put my wal mart lights on months ago they are not brighter then stock but they work and i made my brackets out of the stock ones also.
  • Replies 83
  • Created
  • Last Reply
Top Posters In This Topic
You have to take out the 55w bulbs, go to Home Depot, and get the 35w lights. The 55w bulbs use too much power, and make them real dim.
i did not change them and i can see fine
This is why I said you have to change them from 55w to 35w. The 55w bulbs use more wattage than the stock stator puts out, making them extremely dim. The stator puts out 100 watts. 55x2=110watts. Too much for the stator to light up. 35x2=70watts. Leaves plenty for the CDI, coil, and taillight, making the headlights brighter than the 55w bulbs.
I second that statement.
i have stock stator + wall mart lights and love them just swap out the bulbs for 12v 20w ..... 20buck for the lights 10 for the bulds u can have them on ur shee in about 20 min or so
Also, if you want a little brighter than the 20w bulbs, Home Depot, Lowes, or any home improvement store sells those bulbs. They're in the home interior lighting section. Those little accent lights that you put in houses are regulated down to 12volts. They use the same exact bulb. I think you can get 15, 20, 25, 30, 35, 50, 75, and 100 watt bulbs from there. Just remember, with the stock stator, don't use more than a 35w bulb.
i looked for brighter bulbs when I was at homedepot and I couldnt find nothing... I have a 200watt stator so I was looking for like 75 watt bulbs.. No luck but maybe I will try lowes or does someone know a site on the net where you can buy them?
ok so the moose 205w it is! next!
lights....??????
I assume that was supposed to say 250w. You know that stator is a dual output stator right?
