ok. i have smoke a brand new clutch in one summer.. i am switching over to a lockout with fzr1000 fibers, but i am resuing the clutch steals... should i use some fine sandpaper to ruff up the steels a little?? they are very glazed over.. what should i do? usem the way they are or ruffem up a little??
I have deglazed my steels with sand paper or a finishing pad on my die grinder and it worked good. Do you have and override trans? Lockups make your bike shift hard without an override. Have you tried heavy springs in your clutch? and also if you use the wrong gear oil it can make your clutch slip. I like type F trans fluid it has anti slip agents built into it.
