ive run both stock reeds and vforce 3's on a pretty stock shee and the difference is pretty unbeleivable. with the vforce ones the throttle respose is lightning quick compared to stock and theres a bit more low down power to be had, especailly with a +4 timing advancer
Agreed. Cleaned my throttle up and made it snappier I think.
the power is in the design not the material. vf3 is way better because of the cage and reed shape. carbon fibre's on a stock cage are alot more durable and are designed to run without the stock deflectors, so you can run the pedals the same as the stock ones, and it'll just get a little better, or run without the stock deflectors to change the response. deflectors= better low-mid. without= better mid-top end. i believe boysen even explains this when you go to the online store. i am of course assuming you are talking about replacing the reed pedals, right?
Stock cages with carbon reed petals or designed low-mid range reed will make more low-mid hp than a set of vf3's. The vf3's will make more top end hp on a mid-top motor. VF3's on anything less than a mid-top ported bike are a waste of money.
dont mean to hijack BUT if your thinking of changing cages this might be a help. has anyone heard of or tried chariot performance cages? they come with boyesen reeds. heres a listing
clicky clicky
Edited by jimbob
clicky clicky
I think I have seen another thread recently discussing these...or another companies...hmmm...it's somehwere in the product review section I think.
i can't vouch from experience on them, but talkin with the guy, i was impressed. we were disgussing porting stock cages and he seemed more interesed in helping out, suggesting blaster cages and porting them, giving their experience info, etcetera, than selling me a set. don't get me wrong, vf3's are nice, but the're in it for the bottom line- proffit. chariot obviously has the passion and stamina to design the best possible, and keep goin at it. so i've decided, when i'm ready, i'm gonna go with them. it's like the difference of a gen 1 camaro ss, and a yanko (chariot) imo
ive been running ported blaster reed cages for over 2 years now,they are trick,
the blaster reed pedals are larger than the reeds used on a banshee reed cage.
to use the blaster reed cages you must hog out the intake for the cages to fit.
if your going to port anyway they fit fine.
im sure there's others out there that have tried this mod.
the ones that haven't need to,
i think they out perform the vf3's.
Careful now, the vf3's are sacred!!!
quick q- if i port stock, install blaster cages, then,port them, do you guys have blaster cages designed for the banshee?
