serius4play Posted December 10, 2008 Report Posted December 10, 2008 Wondering how much i shuld take off my head when i shave it down. a messurment would be helpfull. or maby even a compreshion chart. =) Quote
dajogejr Posted December 10, 2008 Report Posted December 10, 2008 Hard to say. Start off by measuring your current head cc's. Because of mass manufacturing processes, I've seen stock heads with as much as 24ccs, as little as 21. Any machine shop can just deck .020 or .030 off of it, but...it would be my recommendation to have a performance shop with a good rep cut and rechamber the head. The questions is...do you want to run pump or race fuel? This is a rough estimation compression chart, scroll down on Noss' site. http://www.nossmachine.com/banshee_heads.htm Quote
serius4play Posted December 11, 2008 Author Report Posted December 11, 2008 Hard to say. Start off by measuring your current head cc's. Because of mass manufacturing processes, I've seen stock heads with as much as 24ccs, as little as 21. Any machine shop can just deck .020 or .030 off of it, but...it would be my recommendation to have a performance shop with a good rep cut and rechamber the head. The questions is...do you want to run pump or race fuel? This is a rough estimation compression chart, scroll down on Noss' site. http://www.nossmachine.com/banshee_heads.htm hmmm. STUPID VARIATIONS!!! why cant things be simple! so what your saying is that it cant just be ground down a bit then put back in. i have to re do the dome it's self? (stock head not cool head with replaceabel domes now that is easy.) Quote
dajogejr Posted December 11, 2008 Report Posted December 11, 2008 hmmm. STUPID VARIATIONS!!! why cant things be simple! so what your saying is that it cant just be ground down a bit then put back in. i have to re do the dome it's self? (stock head not cool head with replaceabel domes now that is easy.) Well... I try my best to err on the side of caution. I'm sure someone will post shave .020 off the surface and slap it on. But that same person won't refund your money or even offer to pay for any damage IF any occurs... An aftermarket head will give you more options....but you pay for that. Sorry I don't have a direct, easy yes or no answer....I'd rather see you spend a little time and money now than possibly a lot more later... Quote
05.Banshee.SE Posted December 11, 2008 Report Posted December 11, 2008 Buy a coolhead, domes, and timing plate...easy Saturday install, and well worth it! Quote
dirtfreak Posted December 12, 2008 Report Posted December 12, 2008 Wondering how much i shuld take off my head when i shave it down. a messurment would be helpfull. or maby even a compreshion chart. =) search the site it has been covered more than once.use .090 solder in your spark plug hole bring your piston up to squish the solder,measure that and it will tell you how much room you have in the combustion chamber.you can mill some but if you go very far it will mess up your squish band.the best thing to do is buy a noss head it will run cooler you will have the advantage of changing domes for diff compression if you want to run race gas or pump fuel.i have shaved heads and you wont notice a seat of pants difference and you motor will run hotter.if you were going to drag race i would say mill it rechamber it but if you want to dune it or trail ride get a noss head. Quote
deckheight Posted December 12, 2008 Report Posted December 12, 2008 IMHO there is very little performance difference between an aftermarket dome and a similarily designed and re-cut OEM casting. Either would produce a similar compression ratio, thus similar horsepower and MSV numbers. And both will generate similar combustion chamber temps. Billet aluminum does transfer heat better than cast aluminum however. And the larger surface area of an aftermarket head shell will improve heat transfer to atmosphere. It is a relatively minimal difference though... Again JMHO If the head will be removed on a regular basis or will see high compression, aftermarket is a no brainer. If it's just going to see pump gas and cost is an issue, cutting an OEM casting might be something to consider??? Quote
AKheathen Posted December 13, 2008 Report Posted December 13, 2008 Hard to say. Start off by measuring your current head cc's. Because of mass manufacturing processes, I've seen stock heads with as much as 24ccs, as little as 21. Any machine shop can just deck .020 or .030 off of it, but...it would be my recommendation to have a performance shop with a good rep cut and rechamber the head. The questions is...do you want to run pump or race fuel? This is a rough estimation compression chart, scroll down on Noss' site. http://www.nossmachine.com/banshee_heads.htm damn it! now you make me wanna pull my head and get out the plexi.- been lookin for an excuse for both anyways Quote
RIPPEN Posted December 13, 2008 Report Posted December 13, 2008 Man if you can pony up the little extra dough I would get a aftermarket head.. Especialy if you plan on further modding your bike.. I originaly had a shaved head on mine that the owner before me did.. Obviously he had never met Dave before because the advise he gave you would have been handy.. When I took my topend apart I could see where the pistons had been hitting the head because they were either not machined properly or just to much.. I have since bought aftermarket and havn't looked back.. Its nice to know that the head I got(noss) will support most any future mods with the chainge of some domes.. RIPPEN Quote
locogato11283 Posted December 13, 2008 Report Posted December 13, 2008 i used to shave my head, but then i realized bitches like a little something to hang on to.. Quote
bbcmudtruck Posted December 13, 2008 Report Posted December 13, 2008 Seems to me that it would be easier for them to hang onto your hips while they are hittin you with a strapon from the back? Quote
deckheight Posted December 13, 2008 Report Posted December 13, 2008 LOL! Every time someone says "shave my head" Its WTF??? Whatever! i used to shave my head, but then i realized bitches like a little something to hang on to.. Quote
