hey all chasing some info on coolheads as i keen to purchase one?my engine is fairly standard besides pipes and the usuall extras and was wondering do i need to make any mods to the motor to fit one?also what size domes would suit a stockish motor
cheers
Chariot and Noss both make a fine head.
I personally like the Chariot for a few reasons.
Less Orings, sleeker look and it's available in Chrome....
It's not like you're choosing between a yugo and a Porsche....these are both good choices and site sponsors.
if you're at or near sea level, I'd get a 20 or 21cc dome to run on pump gas.
Dave has spoken, basically all you need to know. Keeping your compression at 150ish and below will let you run pump gas, most anything above that will need to bump up to raising the oct. or race fuel.
your in australia right?
get noss 19cc domes and run BP Ultimate 98 RON fuel.
thats what we all run up here, exact same elevation mods etc etc... youll love it.
listen to dave and buy the chariot... less o rings and less hassle! i currently have a pro design cool head, and will be making the switch to chariot. i wont make the pro design mistake again!
What is the difference between buying an O ring kit and Buying a head gasket?
You can reuse a metal headgasket...or at least I do.......Ive seen people use gasketmaker.......You can make your own paper gasket from gasketpaper...its really cheap
I reuse o rings and I wouldnt re use a head gasket. The head gasket seals by being compressed. It wont come back to its original thickness when you take the head off. O rings will.
josh
the most important part of an aftermarket head is the combustion chamber design of the dome you are going to use.
in my experience noss are the best off-the-shelf domes.
